Importance of building your own crossover?
use these.plastic terminal connectors.you put the wires in and tighten the screws-thats it.they work great and are real cheap.makes changing and tweaking xovers real simple.this way you can play with different values and learn.
the pic shows a 4 blocks-12 terminals per block.you could cut them apart and use one terminal per connection.
