Hi everyone!
I ordered two sets of this plate for a filter amplifier.
Alimentation linéaires - Module d'Alimentation pour Amplificateur AUDIOPHONICS 50V 4x10000µF
But I ask myself:
Heat diodes mounted on heatsink they are unlikely to shorten the life of the first two capacitors?
Thank you!
But I ask myself:
Thank you!
The heat will reduce the life of the capacitors, that is what u meant to ask.
Yes, but to what degree is a question.
You can insert an insulator between the capacitor and the heatsink. Also you can drill holes in between, on the pcb. Take care not to drill through any copper tracks.
Gajanan Phadte
Gajanan Phadte
