Impedance problem Of O/P Transformer
Hi All
I have a question about the output transformer input impedance. I have an old Philips EL3527 Tape recorder. I have removed the o/p transformer and measured primary impedance and secondary was loaded with an eight ohm resistor. The impedance curve and the data are attached.
Can I consider the impedance of this transformer as 11kOhm (at 1kHz) or 2.2kOhm (at 50 Hz).
Please help.
Renjish
