Impedance correction
I believe the new link is:
Passive Crossover Network Design
...and it is indeed a very good article.
A few questions remain for me...sorry if they are to stupid:
- Is it advisable to correct a woofer impedance peak (self-resonance or bassreflex) ? Obviously we can generate a flat impedance with a RLC...but at the same time we burn power in a power-hungry area...to achieve what ? Lets assume two way speaker, so cross-over frequency is far away.
- Is there a difference in requirements between SE and Push-Pube tube amp, assuming both without NFB and both in Class A ?
- Technical detail: Why are tube amps become louder at impedance peaks ? I understand that the primary impedance of the opt goes up...therefore in theory there is a plus in gain as the loadline is becoming flatter...but do we not loose power as well when this happens ?
An amp with a higher output impedance can alter the woofer resonance. You could design them to work together. ..or you might find changing output transformer taps to find a good bass level isn't the same tap as max output.
It isn't tube amps, it is amps with non-zero output impedance.
Voltage goes up, current goes down, impedance is transformed.
