Dear all,
Who know how to make it.
Just like Analog Device AD1852 Page 15.
Many Thanks
Regards,
nFORCE
Many Thanks
Regards,
nFORCE
Did some fideling on the i2s signals. But i don't have the info on the ad at hand. What do you need to achieve?
Guido
Guido
IIS seperator
Dear,
I want to use 2 DAC instead of ONE to make Differential mode.
Regards,
nFORCE
Dear,
Regards,
nFORCE
You can invert the data line and split off the clock lines and run a pair of DAC chips, one for each of the data lines driven off the came clock lines.
BTW, an XOR chip makes a dandy digital domain absolute phase inversion.
Sheldon
Sheldon
nFORCE,
Check out the 2*TDA1541 post from a while back (search for guido). It contains schematics on how to split i2s to two i2s signals. One for left dac and the other for right dac. You can then choose if the signal needs to be differential or not. Sounds like it.
Is the AD i2s compatibel. Sounds like an old AD to me..
Greetings,
GuidoB
Greetings,
GuidoB
Guido, just looked at your I2S thread. Nice work!
nforce, have you considered the newer AD1955 part? It has the option to select mono left or right mode by register, unfortunately, you will need a controller to change this register.
After reset, it is in PCM stereo mode, I2S, 24 Bit, 256x fs master clock. As I2S is essentially left-justified, I guess it is ok to feed the DAC a 16 bit signal even if it expects 24 bits. I would assume a single 1955 would be as good as two 1853 in stereo mode.
The PCM1738 also offers the mono option, again only via software.
- Digital Source
- IIS data seperator
