If you had $150 -$200 to spend what Midrange/midbass would you buy?
If you had $150- $200 per driver for Midrange/midbass drivers what would you buy?
I want to build a 2 way floorstanding speaker. I do not want to use a driver bigger than 7 inch.
after I figure out driver than I will work on tweeter. As far as tweeter it will definetly be silk dome.
any and all suggestions would be great.
Jordan
jainbaby said:
OK,
I have a Rel sub. So I am ok for deep bass.
Any other suggestions?
Jordan JX92S should do the trick . This is an aluminium-coned full-range/wideband driver , partner it with a ribbon or electrostaric tweeter and they're unsurpassed (to me!) for their $110 pricetag. Hope this helps
316a
