If vinyl can make a come-back
Administrator
Joined 2004
I agree that those WWII Kodachrome photos look odd. Gamma is off, the colorspace is strange and who knows what else. That's early Kodachrome, but it must have been better than that. Either the scans are wonky, or they did something to them in publication.
Without doing extensive tweaks I did some color work and think they are now closer to what they should be. Not a full fix, but better. See below.
Just another Moderator
Joined 2003
I was just hoping that the lack of detail in peoples faces were from a bad print because my only reference to that far back is of pictures of my grandmother and of other B/W pictures from that era.
One thing that I wonder is whether they have used a noise reduction algorithm on these after scanning. They just seem a bit too clean grain wise (though they are small so maybe you wouldn't see it at that resolution).
Even 100 ISO slide film still has visible grain, I've never shot anything lower than that.
Pano, I still haven't looked at the originals on my good monitor, but I should do a side by side comparison.
Note I realised that my comment on colour could be mis-interpreted. When I said even when I'm colour blind I can see things are off, I was referring to the colour (in general) on my laptop :D It's particularly bad!!
Tony.
I love these aircraft radial engines!
Best regards!
35mm, my favourite was Kodachome 64 but I never really had the skill to keep within it's narrow latitude. Colour print was out, too difficult to ensure colour fidelity through to print. For negative film I'd only use monochrome, my favourite being Ilford.
Later on I moved to Fujichrome and found I liked it better than Kodachrome64 because of the easier to use latitude. In this case I had switched up to roll film too, a Twin Lens Reflex.
I would love to have a TLR again, but would want it to be digital.
Joined 2003
My first camera was a TLR, but I've never taken a real photo with it. It was a bent one that my grandfather gave me when I was probably about 3. A voightlander brilliant. I used to go around the house pretending to take pictures of things.
Attached are two pics of it. I took it into a camera shop a while back to get it looked at, but the chassis is bent beyond repair, and would be impossible to get a light seal.
Tony.
I think the financial argument is "it depends". I think if you're love is landscapes, interior photography, travel and for the most part - still subject matter - then certainly film shooting film can get you into amazing second-hand bodies, batteries that last forever, and images that once digitized - are as amazing as full-frame digital.
However, for wild-life photography, people, sports - the flexibility afforded by high-frame-rate and elevated ISO on a digital body is just no match for film.
For a serious hiker/backpacker shooting landscape, I'd shoot Medium Format ; get a Fuji body and a couple of lenses, and be very happy with the work output.
But you can't enjoy any of that until you know how to master Film Economy, making each shutter exposure count - knowing how to expose properly, knowing how to compose in the viewfinder.
