Joined 2003
I wanted to change te textures for the cone, rubber, frame. It only changes the whole driver, even tho I can select each part. I don't seem to find how to do that, if you don't mind sharing if you know how.
Joined 2003
Usually you would just go to part -> compound -> explode compound. The step file appears to include the object as a single solid, so the solution here is to go to Draft -> Modification -> downgrade. This will break the part down into the individual faces.
Here's a nice video on working with STL and STEP files.
