If 4.5" Fostex needs sub & 6" needs tweeter?
Hello I was trying to compare using a Fostex FE167e in a Bob Brines FT1600 MLTL design versus a FE126 in a back loaded horn.
Some people say a full range design should not be any bigger than a 4.5" (FE126) and that you'll probably need a sub. Some people say that with a 6" (FE167) that you might need a tweeter.
I would be using these in a 12' x12' bedroom.
I'm not real crazy about crisp metallic highs and I don't need thumping lows. My wife watches TV in the next room and would complain about the bass. I would think it would be easier to add a tweeter if needed. Just trying to get a few ideas such as back loaded speakers would have to be further from the wall etc.
ya gotta luv the internet
"I read it on the grapevine...."
One guy's opinion (more to follow, no doubt?)
12x12ft is not a huge room, and you could probably get quite adequate SPL and bass extension with a single FE127E in BVR, Fonken, or Mileva style enclosure ; or FE126E in a BLH (not, however the factory recommended hybrid design). Several of these mentioned enclosures are floor-standers, and if you are pressed for room, the little milliFonken with FE127 would be worth consideration.
FE167E in an MLTL such as Bob's, could well overpower a room this size; and the Scottmoose double-mouth BVR's could need more room to properly integrate.
The Fonken's with the Fe126e look nice. I like what i've read about the FE126e more than the Fe127. The miniOnkin likes a bigger amp I have a small Yulong t-amp. I didn't see a milli Fonkin.
What's the point of building a smaller speaker if you have to put it on a speaker stand full of heavy sand. I would just as soon build a floor stander it has the same basic foot print?
Are their any MLTL's with 4" drivers? The Mileva looks good too.
Would like to hear it with a Supravox 165GMF and supertweeter
A bit OT, but me too. From the published info, that driver looks to be the pick of the Supravox line. If I could be assured of build quality and there were more (any?) optimised designs around, I'd seriously consider it.
Now, back to regular programming...
Cheers
horses for courses
As Scott pointed out, the enclosure tuning for the entire Fonken family was optimized for the FE127E (except the microFonken using the FF85K). In the same enclosures, the FE126 would not retain the same tonal balance; - dynamic, yes - but likely very thin on the bottom octaves, and very forward.
Mini-onken in our specific vernacular refers to the CSSFR125 version of the design - in which case, the sensitivity difference would certainly require more power than many small T-amps comfortably provide.
You said this system was for a 12x12ft bedroom, so assuming that there is other furniture (such as bed), that would not necessarily leave a lot of room for a floor-standing or stand-mounted enclosure - hence my suggestion for the milli-Fonken. It's small and light enough when built with plywood that they can easily be hung in a corner with wall-mount bracket - and don't let their size scare you.
There are some things that a narrow baffle, stand-mounted mini-monitor can do very well indeed, of which the Fonkens are a great example. By willfully sacrificing the maximum bass extension and SPLs from a limited excursion driver, such as these in question, and being mindful of room gain/boundary loading, it's possible to lose less than you'd think.
Technically, I think Scott / Dave would refer to the Mileva (& her steroid enhanced brother Demetri) as ML Voigt Pipes (get it, ML-V?)
If you have the floor space, the Mileva or Soott's Brynn (Chang) work very well indeed . In a room this small, 3-4w of SET can be enough for very enjoyable SP levels with virtually any of the FE127 designs, and you certainly wouldn't need to worry about your wife complaining over thumping bass. Hell, if she likes music at all, you might just be sharing the listening couch (bed?).
Thanks for the responces, I'll have to rethink the FE127e as I like the Fonken design. Do you make this enclosure and then cut the front two corners off?
I can't find any reference to the "mili-Fonkin" design.
I will also check out the Mileva and Scott's Brynn (chang) designs as I do have room for floor standers. My original plan was to make MLTL's with FE167e's but someone suggested they might be too big for my room.
Getting back to my original question I guess a 4" fullrange design is better for a small room and 6" speakers are more suited to a larger room such a a living room?
'cause I'm too lazy to carefully pre-cut all the parts to the exact sizes with the bevel (and have access to a large table saw), yes
This might not be the best for you after all, but as I said before, don't let the size fool ya.
http://homepage.mac.com/tlinespeakers/FAL/box-plans/mFonken-0v999-map.pdf
based on personal experience with the FE167 in the Demetri, I can tell you that even a 6" driver can be too large for some rooms ( in my case 8'6"w x 23' long is too small, but 15ft w x 26ft long is fine)
PS, regarding performance in a coincidentally same sized room:
http://www.diyaudio.com/forums/showthread.php?postid=1472281#post1472281
I can tell you that the Fe127e is perfect for a 12x12 room. I just finished a pair for the same size space and they sound great with a surprising amount of bass. Definitely a lot more bass than I was expecting based on what I've read about these drivers. I'd suggest giving them a try and if you don't like the sound (but I bet you will) you can sell them pretty easily in the market place or on ebay.
My favorite small Fostex single driver is the F120A, albeit very expensive and only 89dB sensitivity. With the listening I've done, I'm happy without a tweeter on top but the lower 1-1/2 octaves or so certainly need some additional support.
Not sure if a Fonken type enclosure would be a good match or not.... I've only used them in a 10-liter ported enclosure similar to what Fostex recommend. Maybe Dave or Scott could chime in on the suitability of a Fonken for the F120A.
Regards, KM
Regards, KM
As Dave may have mentioned before, (and I just saw them this evening, so I know they're for real) there is a "Purvined-pair" of these awaiting testing in a Fonkenesque enclosure.
These drivers are so drop-dead gorgeous, it's almost a shame to not OB them - but initial reading of Fostex specs would suggest they're close enough to the rated T/S* of the FE127E to risk dropping them into the same enclosure.
They certainly almost justify the expense of another sheet of bamboo plywood (actually since careful cutting could probably yield 2 pairs from a single sheet..... - I think the carmelized would be nice this time)
*while evidence abounds that Fostex published specs might be "optimistic", it's noteworthy that enclosures designed within comfortable tolerance thereof, have faired reasonably enough
and if they need a woofer, well a CSS SDX7 per side wouldn't be a hurtful match
Thanks Chris... I know about the F120A pair that have been enabled... pretty sure they belong to Jim R. I persuaded him to buy a pair ;-). Needless to say I'm interested in any details on the Fonken-esque enclosure... despite lower sensitivity, they sound much better than the "less expensive" FR Fostex units.
Regards, KM
