IDMAX ideas
Well it might be kind of difficult to use it IB in your home unless you have a nice sturdy wall you want to put a hole in or a huge box. Actually I have seen another guy using an IDMAX in home. I think I saw it on SoundDomain. I want to say he was using it ported? Are you going to be using this for HT or music? The same principles will apply regardless that it is sold as a car audio sub. Actually, I bet the techs at ID would be willing to help you if you give them your goals. If you can't find any use for it, I got $100 😉.
The specs work out decently for a 2 cubic foot box, sealed.
Qtc = 0.7, (that means pretty good).
A ported box would be great, but would require a 5 cu ft box or so, tuned to about 22 Hz. It will give somewhat deeper bass than a 2 cu ft sealed.
So it all depends on how big a box you can tolerate.
