identifying lamp
That looks like a Bayard-Alpert type, high vacuum ionization gage tube. The smaller glass tube gets inserted into a compression seal to the vacuum chamber, with the tip cut off. The heater/filament causes any gas near it to ionize, and produce a small ion current to the small central wire to be measured.
This could be called a P-type tube, since ions form the current with a negative voltage plate. Not too practical except for the intended use. You need a vacuum pump to evacuate it besides. I don't think it comes pre-evacuated, so running the heater will cause it to burn up. The sealed tip is just to keep dust and moisture out until use.
Thanks for your reply!
I assumed that the tube is connected to a vacuum. It seemed strange that there are no manufacturer markings. Also, I want to understand this tube represents some sort of collection interest. I think I have a platform for her to check
