identifying a to92 transistor (S107)
Basically, if the DMM has a diode tester you should be able to measure the BE and BC diode if it's a transistor.
If it's a fet, with the probes between drain and source and touching the gate with your finger the fet should start conducting.
I don't have the correct pin out at hand at the moment so you'll have to find it with some trial and error.
Here a more visual approach; pictures tell a thousand words...
http://www.bcae1.com/ampfail.htm
/Hugo
