Ans: No. It is driver/system dependent. Many Variables.Is there an ideal speaker shape for an open baffle/cardiod speaker?
Ans: Diffraction is mainly a tweeter issue. The least of your concerns when trying to come up with a baffle shape for you midbass!What shape would be ideal for baffle diffraction?
Suggestions: Research 1st. The bible for OB.
http://www.linkwitzlab.com/frontiers.htm
Also helpful:
http://home1.stofanet.dk/troels.gravesen/index_b/OBS.htm
Make a narrow baffle with wood to mount your drivers, then add cardboard to get your desired shape. Measure. Measure some more. Listen. Build. Measure again. Listen. Enjoy
AJ
Thanks for the input John, however, that is not an option. I will be moving in 3 months and will probably move 4-5 times in the next couple of years. I need my speakers to sound good whereever they are... Could a far field measurement be done in an apartment, or would room acoustics cause too much error?
Alex Kunec
Alex Kunec
