Idea for TT feet
One of the mods I have come up with for my TT are these feet. I,m sure someone else has probably done the same thing but it may help someone. It is very effective and cheap.
The answer 4 soft squash ball (approx $12.00), 4 supports used for concrete mesh (50cents each at the hardware store) and some non slip runner matt glued to the base of the supports.(too cheap to count).
The balls fit nicely in tot he holes in the current feet on my table, the supports hold the ball firmly at 4 points. I can bang on the bench the TT sits on and nothing is transferred.
Have fun spinning those black discs.
I'd put a thick slab of ply or hardwood on the squash balls, and if the TT has compliant feet, replace them with solid cones.
If too much mass, add a 5th or even 6th squash ball, and move them around to get the platform level.
Also, I prefer the idea of allowing the balls to 'roll' to a greater extent, restraining them only with dimples, or dots of glue on the bottom surface, which will give better lateral and rotational isolation.
HI Panicos
The supports are made of plastic and the bottom has some non slip rubber matting glued on, they are very stable this way. I have now used this set-up on two turntables, it has proved amazingly effective. More mods are in the wings however and I will post when done.
By the way squash balls come in different hardnesses and you need harder balls for heavier tables.
Aleksunder thanks for you ideas, I will have a play with that to, I think having a dual platform of hard heavy board over several balls and then my supports on top of that might work really well.
When you look at really high end TTs a recurring theme seems to be several layers/levels of isiolation.
Bottom line this approach is cheap so we can easily afford to experiment.
