ID this Brimar rectifier tube from 2x EL84 guitar amp ?
What model is this Brimar rectifier tube from 2x EL84 guitar amp ?
Odd construction with the holes in the anode, not seen one like this before, but don't have much experience with tube rectifiers. Any ideas?
Mystery Brimar Rectifier DIYAudio - Album on Imgur
Tool the foil off, it's a black plastic base.
Also noticed the manufacturer code on the top, which reads:
3H3 133 (depending how you read it).
I have a similar Brimar rectifier to this. Clearly from looking at several photos, it's either a 5V4G or a 5Z4G. As far as I can see they both have the same internal construction and external measurement.
But it's essential to tell them apart since the 5V4G can take 175mA like the GZ32, but the 5Z4 only takes 125mA.
So how do you distinguish between them? They can't be the same valve if the data is different, but they look the same valve all the same??? Quite a conundrum.
It's a 5V4/GZ32. Go to eBay and search "brimar 5V4" and one pops up right away. Nice rectifier, very sweet, used in old Williamson amps. Will actually take 400 volts on the plates without a problem. I use them in my vintage Williamsons. Has slightly higher voltage drop than a 5AR4. It's slow-warm-up...sort of. Not as slow as a 5AR4. If you use it, your PS caps should be rated for full turn-on voltage.
Brimar also made some 4V rectifiers which have the same plates, 10E/9600, 10E/574, VU39A for example.
These have a different base/pin construction and that would be the difference to look for.
But anyway, 133 is a 5V4G type so thats what it is.
