ICEpower 1000A help to identify parts missing
Hi All
Please help to identify the parts marked in the Ice Power 1000a module picture they are adjacent to the input connector. I have 2 modules one the parts have unfortunately come off and got lost in transit and one module with the parts populated. Most of the components are marked and identifiable, somehow the parts that went missing are not marked.
Below is the module with the parts missing in blue
Below is a picture of the module that is with all the components.
Thanks.
Hi
I have tried to get the datasheet but was unable to find it, measuring the parts of the good board is a gr8 suggestion however I am not very experienced with s.m.t. (only worked with old school parts) , not sure if I will be able to de-solder and measure without making a mess of it, and unsure if the correct values can be obtained by measuring with the parts soldered to the board, please suggest. There is very less info on 1000a , or 1000asp - the amp part....
Hi Anode, if you have the datasheet it will be very helpful if you could share it
Reviving an old thread.
The first blue line is a 6.7ohm smd resistor.
The 2 in the center of the 4x lines are diodes for the mute signal. One is +12 one is -12, unsure of the values.
The lower of the 4x lines is a 4.7ohm smd resistor.
The board will not function without them.
You are also missing the 2x 3F 22 35v capacitors in the bottom right corner.
I'm interested in buying the 2 boards if you still have them ?
