I spend most of my time here in the multi-way forum. So I'm posting this here because there have been discussions looking for amplifiers for DIY active speakers.
https://bellarossafabrica.net/6-channel-amplifier
I decided I wanted to replace the very heavy 8-channel SpeakerCraft BB865 Class A/B 8-channel amplifier I use to drive some active 3-way stand mounts in my office. There were no problems with the existing sound, but the amplifier was causing the shelf it was sitting on to sag a bit. I wanted something lighter, so I made my mind up to build a 6-channel class D amplifier to replace the 8-channel class A/B. I decided to use pre-built class D modules rather than build something from scratch because I never had a talent for trouble-shooting switching power supplies, and class D circuits seemed...
Great job and great write up!
btw, how do you like the dbx PA2? It seems really convenient. Do you have any passive protection components for the drivers?
Thank you
The PA2 is okay, I had been using a QSC basis but it was acting up so I decided to replace it. The I like the flexibility of the QSC better and Auto EQ of the PA2 more. After I swapped the PA2 I popped the cover off the QSC and the power connector was loose, once I reseated the connector it was stable again but I don't feel like going back.
I have 22uF capps in line with the ribbon tweeters, but the mids and woofers are directly connected to the amps. I'm confident the IceMatch won't hurt the drivers and only a problem with the crossover would damage the tweeters, therefore I have the caps.
