It's possible that the 3120 is damaged but if the 100 ohm resistor is burning, the FETs are likely damaged.
You also need to check the surface mount diode hear the FETs. If it's shorted, it may be able to cause the resistor to overheat.
The Zener diode is marked J5. It's a 20v Zener.
