Any interest in a small Group Buy for a quad output version of the venerable First Watt transformer? This could be used with two power supply boards (which could each serve a single channel) which could result in more overall capacitance, allow some more creative higher density layouts...
If there is some interest, I can chat with Plitron and see what the cost might be.
Ok, I will have quotes this week on both a 4x22 and 4x18 400VA with 2x117 primaries.
I think I will keep things small, so register interest this week and we will make this a quick turn around.
Ok, I'm looking at a buy of 10 400VA 4x22 and 10 400VA 4x18. The prices (not including shipping to me or to you) run:
$107.00
The final diameter is 123mm and height is 63mm and weight is 3.37kg (for both).
Please add your name to the list below:
$107.00
name | 22VAC | 18VAC
luvdunhill | 2 | 4
Mordikai / 2 / 2
remaining | 6 | 4
Can everyone also include their location - specifically if US so I can take advantage of flat rate packaging.
luvdunhill | 2 | 4
Mordikai / 2 / 2
ICHIBAN |1 | 0 |
remaining | 5 | 4 |
One 22VAC trany for me.
Tonawanda, N.Y. 14150
luvdunhill | 2 | 4
Mordikai / 2 / 2
ICHIBAN |1 | 0 |
remaining | 5 | 4 |
Shipping from Plitron to me will run $8.60/ea.
If we don't get up to 10 each, then the additional cost for these numbers will be $6.42 each.
No problem. There doesn't seem to be as much interest in this one as I thought. I'm going to set a close date of 12/5 at which time I'll contact the participants and see if they want to move higher with slightly higher per unit costs.
- Group Buys
- IC: Plitron 300VA 4x18VAC Transformer
