I bought a used Ibanez TSA-15H. Great little amp and works really well. It has one fault though. The power will randomly cut out, i.e. the power indicator as well as all sound goes out.
This will normally happen while the amp has been on for a while, but it has happened shortly after power up. sometimes it works fine with no power cuts.
Any ideas? I was wondering if it might be the the regulator feeding the preamp heaters and power light that's failing? It also looks like it might have a thermal fuse on the mains section?
