Supposedly this amp is very rare, very sought after, and exceptionally good at SQ performance. This is a 6 channel low power amplifier. It has channel 1 through 4, a center channel, and lastly a subwoofer channel. i dont expect this amplifier to be all that rediculous by the looks of the 30A fuse, but none-the-less I am told this amp is hand built in England and is one of the 'best' according to a long-time installer.
This amp accepts power and powers up, only after about ~30 seconds the two long-thin resistors next to the fan get proportionally hotter than I would like. On the PCB it says these resistors should be 100R5W but are measuring 170Ohms. I'm likely going to pull them off and test them on the bench.
Sometimes revisions are made and the boards have already been printed. This means that the silkscreen may not be accurate.
It's possible that overheating could make them drift and since they're essentially identical, they may change in value in a similar way but it's unlikely that they would both be the same value.
I think I'd leave them as they are.
The top one in the photo hit 320 degrees F after about 5 minutes of playing time. I unfortunately do not have the top cover to this amplifier. i wonder if these resistors are supposed to be heat sync'd.
If nothing else, I think this amplifier is fine as it plays clean on all channels.
I don't think their location near the fan is an accident. I think the fan is supposed to keep them cool.
If one is getting much hotter than the other, there may be a problem. If both are at the same temperature, it may be normal.
This type of resistor (from what I can tell from the photo) appears to be made to handle high temperatures. Some resistors can withstand 500°+ continuously. Although 320°is hot, it may not mean that the resistor is in danger of failing.
- General Interest
- Car Audio
- I was handed a Genesis P51 V2.2
