I want pre-amp schematic with A s/n ratio 92 db or more
If you want your preamp to be able to accept 2Vrms at it's input, then if the input noise must be lower than 92dB, this will equal:
2 x 10^-4.6 / sqrt(20KHz (bandwidth)) = 349nV/sqrt(Hz)
It's hard to design something so noisy. Every opamp known to me has an input noise lower than 40nV/sqrt(Hz), take you pick, NE5534, or opa227 (both about 3.5 nV/sqrt(Hz)), opa134 (about 8nV/sqrt(Hz) ? ).
Edit..: oops allmost forgot: Nelsons MOSFET preamps will meet this criterium too. BTW what is the EIN of a IRF610? something like 20nV/sqrt(Hz) ?
But if you want 92dB S/N for a 2mVrms (max input) preamp, you'll have a challange... you'll have to build a discrete BJT preamp, eg. a 6 transistor symmetrical input stage with Vbc = 0Volt and 300uA Iq each transistor, or a handfull 2SK170's in parrallel...
Goodluck,
Thijs
A low noise power supply is vital to get good performance of a preamp.
Also pay attention to PCB layout and internal wiring to avoid ground loops.
Will you use discrete components or use Op-Amps?
The Aleph P mentionend in this thread is an example of a good amplifier.
