I need to add a phono o/p to fm tuner
Hello
I have a denon tu-260l fm tuner feeding my quad34 preamp and 401/2 amp. Problem is there is no headphone output on the fm tuner so I would like to add a headphone output jack and some internal headphone amp, probably ebay diy.
I realy need advice on loading the audio output to the quad, would this effect the audio quality.
I also could do with a schematic for the denon tu-260l.
Has anyone any ideas on this mod.
thyristor44
The Denon uses a simple emitter follower output stage of modest drive ability and so you need to be careful what you hang on there.
Two easy choices.
1/ DIY using an opamp.
2/ Something like the TDA2822M chip (loads on ebay) which is perfect for headphone use if you pad the output down with a couple of resistors. Single rail, low current draw, high input impedance.
What's not to like 🙂
