I need the input format(s) of this DAC Ic
Iain McNeill said:
not standard I2S as the data is valid on the 1st rising clock after LRCLK. Analog Devices calls this "left justified"
Not sure what Japanese standard is.
Do you know what's coming out of your source? Can you get at the configuration registers?
Hello
I did email you a file by your web site.
Thank
Bye
Gaetan
HI Gaetan.
Looking for the datasheets for the parts on the schematic you sent me I see you have already searched for the audio processor and DAC datasheets.
http://www.electronicspoint.com/need-data-sheet-td6709-t115636.html
As usual with the consumer equipment, the datasheets aren't available.
You'll need to get a scope on the DATA line, triggered off the LRCLK line. Measure the bit width (that'll give you the bit clock rate) and see on which edge of bitclock the data is clocked. Then you'll know if you can bolt your DAC onto the Toshiba.
Unless someone out there has already reverse engineered your model.
