hey, im in serious need of some info...
i desperately need a site/person to run me thru watts at ohms and stuff... i understand most but some of it becomes an aeroplane straight over my head... 😕 ...
anyone with Beginners Guide or Dummys guide to, drop us a reply plz
thank you... but i already knew that stuff. i did physics in high school. 😉 but i want/need to know how it relates to speakers, subs and amps...
any help plz?
any help plz?
Mostly: U = R x I -- I'm not joking .....
As you are educated you might know how to search?
But mostly U = R x I will do the job.
And sometimes a little P = U x I
If you hang around here long enough
you will soon be "in it" all.
Some real ADVANCED PERSONS, (not Nelson Pass - amazingly! - he is probably to clever for that)
have reach so far that they are totally lost
in formulas that noone else understands
and that no longer relate to REAL WORLD AUDIO. 😉
Try to avoid to go there - it is a serious illness!
You yourself are totally unaware - while others just smile at you.
Stay with the basic.
Whatever 😱 formulas you like to associate with 😱
Current just keeps on creating Voltages over Resistances
whether it is Alternating Current, AC, or Direct Current, DC.
And things will stay that way a long time from now.
halo - 😉 don't mind people smiling at his words 😉
I don't feel like searching the web for a tutorial.Kon said:thank you... but i already knew that stuff. i did physics in high school. 😉 but i want/need to know how it relates to speakers, subs and amps...
any help plz?
again, very little towards wat i need...
here's my story
i am buying a set of speakers/subs and an amp for my car. i am reaing specs and amps are talking about 100W@4ohms or 150W@8ohms or wateva... (ps not real numbers, just approx) now i need to understand wat i need...
say i have a 4x100W @4ohms, can i have 4 speakers with power 100W AND a sub ??? 😕 ??? or something different???
i basically want to know the relationship between amp-speakers-subs and the W, Ohms, etc....
plz
here's my story
plz
I don't think we can help you 🙄
a 4*100watt @4ohm amp can drive 4 100watt, 4 ohm speakers...
Umm..... I'm lost.. 😕 😕
tell us what you want to do, and well tell you what you need to do.. 🙂 what speakers? how many, what wattage, etc.. 🙂
Refine your question
- Preferable one specific question at the time. (Or two)
- Give as much facts as possible
- You will get more interested, if you post a diagram or picture
to illustrate the subject.
The more specific you are in your question
the better answer you get.
Halo - has seen it work this way - here at the Forum
(some people are impossible to reply to - they do not know how to ask)
You need to refine your way to ask.Kon said:again, very little towards wat i need...
here's my story
plz![]()
Re: Refine your question
Now, don't be too harsh.... ....on me... 🙂
Well, I'll take a stab at what Kon wants.
Most car speakers are 4 ohms. Most car amps deliver their highest power into a 4 ohm load.
An amp rated for 4 ohms can in fact drive an 8 ohm speaker. However, it will not deliver it's highest power into it. So an amp rated as 150 watts into 4 ohms might deliver just 75 watts into 8 ohms.
If you hook two 4 ohm speakers together in series you get an 8 ohm load. If you hook them together in parallel you get a 2 ohm load. Some of today's better car amps deliver their highest power rating into 2 ohm loads, actually. This is a departure from the traditional 4 ohm load for car speakers. Indeed, there are now some car subs that are actually rated at 2 ohms. Check that when you buy your speakers and subs.
There is an advantage to listing the Sound Pressure Level of a speaker with an "@ 2.83 Volts" listing. Actually, this is confusing. The lower the impedance, the more current a speaker draws at 2.83 Volts, hence more power is drawn, hence a higher "SPL @ 2.83 Volts" rating. But the speaker is really not more sensitive or efficient!
At 2.83 Volts, an 8 ohm speaker draws 1 watt, a 4 ohm speaker draws 2 watts, a 2 ohms speaker draws 4 watts. So the 4 ohm speaker will appear to be 3 dB more sensitive than the 8 ohm, and the 2 ohm speaker will appear to be 3 dB more senstitive than the 4 ohm. But they are not-they are merely drawing more power at the measured voltage. They still play the same SPL at 1 watt.
Speakers actually should be rated "@ 1 Watt", and some car speaker manufacturers, notably Blaupunkt and others, do it that way. But be aware of the SPL measured "@ 1W/1M" if the speaker is a 4 ohm or 2 ohm speaker. As stated before, the speaker wil not be playing at one watt at that voltage level.
Actual impedance is usually about 25% higher than the DC resistance. So if a speaker has a DC resistance of 2.8 ohms, it will be close enough to a 4 ohm speaker. But if the speaker has a DC resisitance of 1.8 ohms, then it really should be called a 2 ohm speaker, and might blow a 4 ohm amplifier.
Any other questions, please let me know.
YIPEEE!!! Thank you somuch KelticWizard... that was the explanation i needed... im forever in ur debt...
sorry halojoy, you were right i didnt word my question right..
YAY 😀 😀 😀
YAY 😀 😀 😀
No problem. If you have any more questions, feel free to ask. That is what this forum is for. 🙂 🙂
I am also greatful for Kelticwizard, making this good explanation.Kon said:YIPEEE!!! Thank you somuch KelticWizard... that was the explanation i needed... im forever in ur debt...
YAY 😀 😀 😀
I am often to impatient to do like him.
But just by making such "a little tips" as I did
I have, at several occations:
1) made someone rephrase his Q, and post some more facts/diagram
2) put the focus onto the thread! - it is placed on top of the list!
3) making some remarks - that give initial info - and sets the direction of the discussion
In that way I find I have helped a number of people
although the most substancial information/help
was giving buy my comrades - here at DIYAUDIO.
We have specialists & experts in so many areas/subjects.
I see myself more as a link - some sort of GREASE that makes other things work well
- calling these guys to the place, where they can contribute
in this great MOTOR-engine called www.diyaudio.com
sometimes all that is needed is a friendly post
some nice words -
show a person, someone have noticed his Question
/halo - sometimes a very nice & helpful man
- handles the spotlights shining on you ...
- I Need Help!!!
