I just purchased 102 pieces of optics from ebay!
Re: off topic
Negative Design said:
DNT, i saw the auction you won earlier and i wanted to know if you plan or know how to fix it?
please keep me updated 🙂
good luck
troubleshoot lol🙂
with electronics it could be anything hopefully its simple.
I'll have to get out my very old electronic skills.
Why are you having a similar problem like this
f so what have you tried
Projection Anastismat Lens
I did'nt know where else to put this post, but I did'nt want to start another thread.
Also I have search till my eyes hurt for the answer but found nothing.
My question is exactly what does this lens do.
Re: off topic
good luck
Negative Design,
Iwould like to update you on the spectra c.
When I first turn it on it did exactly like the auction description said it did (power up then light goes out). I turned the OHP on then laid it on top it came back on and stayed on, but i had zillions of horizontal lines. messed with it awhile without opening it up but it did no good. I took it completely apart and clesned all surfaces as i went just in case I got it to work ****which I did***
I thoughtat first it was the male 15 pin connector so I checked to see if it was tight and all and seemed to be. checked other things and tapped around LOL. I still couldnt get to work until I changed the setting on my PC from 800x600 to the 640x 480?? setting. Im at 70 inch projection now with a 5and half dollar Apollo 2 OHP. which is brand new top glass was broken he the seller said it didnt have the arm and projection lens( which was mounted inside the projector housing. so I spent to $80 US on my set up.
Use it or make some cash?
I plan to use it for awhile until I upgrade. I plan to go the monitor route. I hear some good things about the 1560m NEC I think.
I found another one for $125 USD but thats pricey for this panel I think.
Oh yeah forgot to mention the reason it wouldnt stay powered up when they tested it there is a light censor in the panel ( well thats what it looks like) if they would have placed it on a OHP it would have stayed powered up. Reason I telling this is cause I didnt know about it.
