Hi guys.. only recently(over the last year or so) have i become interested in audio. A few years ago i had an amplifier that died(2 channel 60 watt/8 ohm sansui amp - was pretty old, probably late 80s.' one day i came home to find that a speaker terminal was shorted, the speaker fuses didnt blow but the mains fuse did. it had overheated. i no longer have the amp but does anyone have an idea why it died? could the output transistors/other transistors have internally fused themself?
Every time i replaced the fuse it blew it instantly
thanks, tensop.
thanks, tensop.
Seems mostly like one or more output transistors had shortend...
This could be because of age or over heating 😉
If a amplifier speaker terminal is shorted and the amplifier does not have a protection circuit for this, then usually the output transistors blow first, protecting the fuse 🙂 The fuse blows too, but seconds later.
In many japanese amps are used fusible resistors at critical positions - try if any is not interrupt.
