I found this old "fellow" when surfing, a friend told me to change those parts.
What do you think?
Will those changes increase the amplifier "sonic" qualities?
Are there some mistake on it?
Do you think can change other parts?.... what parts?
regards diy guys
Carlos
Hmm, could anyone enlighten me on why the inverting input resistance is 10ohms reference to ground?
Wouldn't this result in a rather unbalanced current at the input from the source?
Also, the output stage is fused on either rail. What happens when one side blows and the other doesn't?
No time to observe what really happens, must go out for breakfast!
The only changes i would make is as you said remove this strange
resistor in output, reduce coil to 2uH, reduce stopresistor to ~10ohm.
You should keep the bc639, as i remember it is identical to bd139,
only other case.
And you should replace the 2 output-bjt-pairs with something like
mjl21193/4 or mj15003/4 or mj15024. An keep the 0.22ohm ?
And you might replace d3 with a matched bc640, the "standard"way
for a currentmirror.
Mike
