I don't believe cables make a difference, any input?
Has anyone yet learned something new about cables that they were not interested in previously? Have you noted the change in Dielectric constant with frequency and materials? How about DA? Skin effect? The effect of conductor thickness on inductance? These are topics that should have been studied about, before launching in criticism of others and their personal experience with cables.
In the 1970es, the Danish monthly high fidelity tested high end products as follows: the component circulated between the 5 reviewers: Each had the component for one month. The reviewers had very diverse reference systems according to their own preferences. After evaluating the sound of the component for one month, each reviewer would describe his impressions in a letter that was send to the leader of the review. These 5 letters would not be opened until the five-month-long test was completed. It was forbidden to communicate the impression of the component to others before. The leader would merge the impressions from the 5 reviewers into an article in high fidelity. Measurements were done a f t e r the article was written to reduce bias. The interesting part is (I know the leader of these reviews well) that typically these 5 reviewers had very similar impressions of the components (however the Pioneer M-22 power amplifier was an exception, getting mixed reviews regarding the dynamic capabilities and soundstage).
What I would suggest is that a unrecognisable = not marketed (to reduce bias /prejudice) cable is produced, and is sent for 5 contributors to this thread in a similar manner to above mentioned. Five secret one-month reviews are collected and a conclusion is drawn. Measurements should be made afterwards.
This test would be fun for the contributors and inexpensive (cheap postage). I have a cable-set in mind, that you could try out. I will insist that the one and only set is used, and that the connectors are not disassembled. This is to avoid injury to the cable, not to hide radiocontrolled components inside 🙂
Hey this sounds reasonable.😀
Only if they were claimed as causal by those hearing cables. Otherwise, the effects you list are generally acknowledged as so small as to be immaterial when cabling is applied in "normal" quantities and situations.
Even if they WERE real and material, they are all constants of sorts - and hence universally applicable. Yet we still are subject to claims of event, time or equipment specific results.
Either way, there are a lot more basic questions to be answered before we trouble ourselves with the difference in dielectric effect of red and black cable sheathing...
That you can hear, what you will hear, was not the question. Again, I believe you.
I said a few thousand posts before that I can accept a test but without switching box,but I was told I live very far.Those who are really interrested to see if what I say I hear is real,are welcome anytime.
Does this answers your question?If you would feel happier with any other answer,let me know.I will answer any way you like.Afterall Christmas is coming,and the thread is about to explode any minute.:bomb:
You haven't told me how YOU know that what you hear is real.
Yeah, that does sound reasonable. As long as a specific protocol reviewing and setup was defined ... like what terminology to use, and where to place the cable.
You'd need a score card, something like this:
Brightness - 1 2 3 4 5
Soundstage - 1 2 3 4 5
Dynamics - 1 2 3 4 5
Bass - 1 2 3 4 5
Imaging - 1 2 3 4 5
Transparency - 1 2 3 4 5
1 = less/worse, 5 = more/better
Intangibles (free review):
And the score for each cable should only be referenced to the other cables. Then add up the score for each cable. And see if the same cables win in the defined areas.
Need more than 5 reviewers, more like 25 reviewers and 25 cables? Or could circulate the cables but we'd have to quit posting or leave enough posts before 10,000 so we could do the test and get the results. 🙄
and still we assume that people can perceive a difference...
I'd go even simpler. Heres the script:
Quesiton 1 - can you hear a difference between the cables tested when you are prompted?
(x number of prompts advise the change (or purported change) of the cable)
No need for ANY more questions until this one is proven - see you guys in six months.
Easy. Lets do it at John C's or Curly's. They have great gear - all mine's crap. Apparently.
I saw panikos comment later, but am still not convinced. Why is a switch box a magic switch box?
Why does it only seem to bring the good one down to the bad level?
I've explained in a post to Doomlord why I'm sceptical about switchboxes.
Andre, I recall your comment that the wrong cable can make a $10000 speaker sound like a $5000 speaker.
that does NOT imply small effects. It in0plies large, easily noticable profound effects would you not agree??
With these cables I've mentioned, I will tell the difference while standing in the kitchen. 😀 I've explained earlier that you can use cables to hide or highlight certain aspects in a system, if you get it wrong, it will certainly be very audible.
So can you hear the studio cabling effects in these recordings?
They must all use "good" (your self defined term) cabling I assume, without any loss of detail and "resolving-ness".
Or do your "good" cables somehow (no "good" explanation required or expected) reverse/transmogrify any "bad" cabling effects embedded in the recordings?
Good recordings will obviously be made with good equipment, including cables. You can never put back what is lost.
Hell you only need to take a speaker out of the shop and it drops 50% in value... Does its sound change too???
Heres a thought - speaker manufacturers would have a strong incentive to ensure their $10k speaker maintains its value - surely they have the resources and smarts to put a big sticker (removable of course) on the enclosure pointing out that such and such is the minimum spec for cabling for that speaker, or even more pointedly, the speaker will not perform to its optimum unless used with so and so's cable?
Now, why don't they do that?
Oh, I smell chicken!!! We send them only to people who can hear a difference (i.e. cable believers). It has to be an extended listening test.
I think that it is important to study a subject, before you can successfully form a strong opinion about it.
Carts and horses John. Given there is no current proof that cables of reasonable quality and build make any audible difference in a complete system, it seems premature to go looking for causes for that effect.
As stated before, I believe that you and others perceive differences and make judgements based on those perceptions. I believe you and others (but not some others again) do this in good faith and with only the best interests of your system, your clients systems and the wider audio community at heart regardless of whether or not you are rewarded financially - a mans gotta live after all!
I want to emphasise this is not a question of personal integrity. But it is a question of scientific proof.
So, in the search for first principles, we should put to bed the argument at the bottom of the heap - can people hear differences between cables (interconnects and speaker).
Only once that question is answered (and only if in the positive) does the question of incremental differences between cable constructions become of interest.
what if they get different ratings? Does that mean they made it up, or experienced differently?
In the first instance, you HAVE to ask a binary question imho. As I've pointed out, we can't even agree on IF there is a difference to hear let alone the nuances if there is a difference.
KISS
Not only that, if you send it only to believers (and I don't think the chain letter cable is a valid test, but anyhooo) then the only ones who will be involved and accepting of a positive result are the believers. Of course a null result will have the agnostics and heretics absolutely ecstatic, but with no good reason since the test itself is tainted and flawed regardless of outcome.
Drug companies don't test on just those with a belief in a cure. They test randomly. Let that be your guide.
forgot to add on the point 'my ears are not your ears'.
Take even the most basic of audio concepts, centre image.
I set up my system (using whatever I needed to) so that the centre image was dead centre for me. (we had it all measured yada yada, and we could point to the exact mid centre point etc).
And I sat my mate down, and played the stuff to him (pink noise, test tracks 'the sound should be coming ...' etc etc).
We could not agree on this most simple and basic part of audio reproduction! Our centres differed by six or eight inches!! (was a long time ago now) Of course test a lot and there will be some that agree with me, some to the left and some to the right etc etc.
Centre image is at least a 'concrete' thing we can all agree on and actually test for. If we hear so differently on basics like that, how can we ever agree on 'chocolate midrange with a hint of cinnamon'????
(I am assuming that the both of us have 'normal' hearing, and am pretty confident of that)
Easy. Centre image is an ILLUSION, created by (among other things) balancing the relative levels in both ears. Get a different pair of ears, you can get a different balance point. OBTW the centre image ILLUSION is also reinforced by the visual situation. Try increasing the level in one speaker slightly over the other, then try to find the centre image. It will look somewhat wrong because it will not correpond to the visual centre. Interesting experiment.
jd
Excellent point. One thing my speakers do really, really well for me is image and create a very tight center when fed a mono signal. There's a TV set between and behind them, and with a mono signal, I'd swear that the sound source is the TV. But for The Eye Lady, they don't put the image in the middle. What's the difference? She's partially deaf in one ear (the side where the PA system was in her musician days), so what sounds dead center to me is pulled to the side for her.
I've said it before, but it may bear repeating- once you collapse a complex 3-d soundfield into two single-valued channels, all the other compromises are pretty minor.
