I don't believe cables make a difference, any input?
These two are from the latest (126th) convention.
Created by Camtasia Studio 6
Thank you very much for the links.
His tutorial on magnetic induction, ground loop topology effects, transmission line theory and application are rudimentary and incomplete. It is interesting to see mis-conception at this level. I was hoping for better.
He states that he searched for information on where that loop voltage comes from. He did not do a very good search. I initially posted on five different forums, starting May 4, 2004, with many posts on this since.
Soongsc, very good work. Again, thanks.
Cheers, John
Cheers, John
I've learned a lot form your posts over the years as well. Thanks.
The value of all this discussion is hope that someone might be inspired, and possibly find things that might have slipped by the eyes of others.
Application permitting, I might try the 4 lead cable configuration some time.
Holy Moses - and all the rest of that family too!
Basically- what some of you are now saying is that Ohm's Law, the transmission line equations, and roughly all theory that has been taught in engineering in the last 100 years and basically runs the world these days, are all wrong, because you say it is, - but you just can't prove it!... ??????
Basically, you must re-read my post and understand what was actually stated.
There is a significant difference between stating that a person misconstrued the theory, and stating that the theory is incorrect.
A good example is transmission line theory. At audio frequencies for example, the velocity of propagation along short lengths of wire must be mathematically transformed to accomodate the line to load mismatch, the effective dielectric constant (which is proportional to the produce L and C), and the length of the line.
The only time one can consider the velocity of propagation to be proportional to 1/sqr(LC) is when the load impedance matches the line impedance. That never occurs with IC's, nor with speaker runs.
Easily proven. And, I have done so in the past.
Cheers, John
