I don't believe cables make a difference, any input?
"champ04" interesting thoughts on speedskating. Having seen most of the Long & Short track Wold Class skaters race (and having been on the ice with some of them when they were younger) you have nailed an important factor in competition.
Now about DBT's. Why do DBT's work well in many other areas of Audio and Acoustics yet the have so many problems in this discussion? DBT's work with audio compression formats and are sensitive to very small JND tests.
Look, I did blind testing 30 years ago, and even wrote it up. You don't have to compare wires, just compare preamps. Can't hear those either. This test is a set-up to make people who actually hear differences, not be able to, and therefore dent their credibility.
Now, I am almost 68 years old, I usually could care less about wire direction, although others, over the years, have found it important, and I don't even have a favorite connecting wire that I can recommend. Why would I do this test?
The problem with blind testing like this, is that you lose what you are listening to with the changes in the music. This has been proven by the numerous failures to be able to get successful positives in the test over the last 30 years.
What happens is that the differences seem to disappear, then they come back with knowing what you are listening to, just like magic. Well, if you believe in magic, this would be a good example, but I believe it is the test, itself, that is the problem.
I am not against testing, just this kind of testing.
You sure do say a lot for not saying anything.
Yes,but that doesn't give Jakob2 and Jon Risch any right to call anyone who did an honest effort(better than nothing here so far),like me or my friends any names.Jakob2's position is clear on this I think,see a few posts earlier.
Politeness has never harmed anyone 🙂
You didn't address the questions, so let me respectfully and politely ask once more🙂.
Are blind tests (SBT/DBT) the valid methods for determining (subtle) audio differences (as opposed to dreamy, uncontrolled "listening")?
If they are, must they be conducted robustly, by experts like Jakob2/Jon Risch, who know all the pitfalls of the sloppy testing?
cheers,
AJ
btw, no one questioned your honestly, just the robustness of methods and awareness of pitfalls via expereience
Because they don't support the validity of beliefs, just the effects of plain 'ol sound waves.
How do we truly know that DBT's have proven to be valuable in audio?
Wow, no land line, cell phone or VOI? How do you verbally communicate with those not in proximity?
It will never be 'robust' enough to gain any real credibility, because the hear-nothings are working from a conclusion, in advance, (there is no difference), and any positive results will be attributed to: "good luck" and negative results will give "I told you so".
Do you call this "peeking" in the states😀
To reply your question,as long as there is no switching box and extra cables involved,and cables are swapped manually I have no problem to test myself blindly,as I did a few times so far.I don't know if this type of test is the only valid way though.It just seems ok to me and the easiest for us to do here.What I can say though,is that I needed more effort to tell which was which than when I do this sighted.Also,even in sighted tests,my expectations(when I have any) are not always met.I always try not to have any expectations when I test things in my system.In fact if I have any,it is mostly in favor of the things I already have🙂
I am really a 'hear-less' than a 'hear-nothing' It is caused by old age and loud music (you can't work on the stage with the Grateful Dead, and not subject yourself to potential hearing damage). However, at 24 years old, I had great hearing, and I'm sure there are others, in that same age range. The rest is interest and ability to hear differences in musical instruments and hi fi systems. They are the ideal test subjects.
Well here are snapshots of my "hear nothing" ability:
Yours? dbe's, Panicos et al???
Any evidence or just claims?
cheers,
AJ
What's that?
My result with terratec 24/192 soundcard and small creative PC speakers (1" driver):
Well I'm 29 but I got out of live sound only after a couple of shows. And I used earplugs after the first night of abuse - I know I'm a "nerd". So I do think I would be a decent subject. I still have that cockiness that if there is in fact something to be heard I should be able to spot it.
Implementation. I've droned on before about the differences between the typical audiophile ABX/DBT and the acoustic test protocols I saw at a professional acoustic lab. Like I wrote earlier, I have never, and I mean never, seen an account of a DBT that returned a null result criticized by a 'testie'. 😀 Such a strong belief system automatically raises my suspicions.
Precisely. If reasoning was used, the absurdity of the argument that "psychology can't explain everything" when we are specifically concerned with the psychological component of "hearing"....would have been obvious. Thanks for reaffirming.
Nonsense. YOU are starting from the position that psychology can explain everything and therefor it is only you who is specifically concerned with the psychological component of hearing.
We know from physiology that when a body is exposed to a stress of any type (this includes any expectation of performance) that components in the body, specifically but not limited to musculature, tend to become more rigid.
The tautness of the eardrum is controlled by tiny muscles, is it not? (it is)
Any increased tension of this muscle would cause the dynamic range of the listener to decrease. This could logically explain the decreased perception of the subtleties in the music.
No, its not proof. Its just one plausible explanation of whats going on. And it has nothing to do with psychology.(other than the psychological impact of performance expectation) It is certainly reason enough for further inquisition which has been my central point from the beginning.
A reverse of this situation, though completely anecdotal, would be what elite athletes describe experiencing when achieving "Flow". Flow is the term used to describe that rare occasion when everything comes together and an ultimate performance is achieved and is itself a completely unique line of study.
In these situations athletes often report an extremely heightened level of perception. Such as being able to hear only the voice of their coach amidst the ruckus of the crowd, as just one example.
What is consistent in the reporting is this heightened perception along with an overwhelming sense of ease and control. Ie. zero tension or stress.
<snip>
Oh, even that happens once in a while; in nearly all cases i remember the critic was dropped if it doesn´t came handy anymore in a discussion. I´d guess it depends on the definitions of the term "objectivist" in use.
Wishes
