No, John.
I read what you recommended. After I did, you kept stone silent.
Now it's your turn to put your money where your mouth is:
jd
I beg your pardon? I read the abstract and stated that it was not about the issue discussed here. Then you urged me to read the whole paper 'and learn something new'. To avoid that you would made a fuss of me refusing to read a paper, I spend an hour to read it. Surprisingly, the paper was about what it said in the abstract.
Now you complain that 'nobody reads it'.
What's your point with this paper? I read it, am waiting for your input, probably in vain.
To repent, you will buy and read:
A Mind of Its Own: How Your Brain Distorts and Deceives (Paperback),
by Cordelia Fine; or forever keep your peace 😉
jd
jd
Andre Visser:
Is this a rhetorical question??? What do you mean by 'don't even believe in stage focus' and why are you implying that he might not 'believe' in it? If he doesn't care about stage focus, why should he choose for it? Why do you assume that everyone who buys a hifi wants to go out and 'audition' lots of different equipment when there are alternative but equally rational bases for choosing equipment.How do you choose and set up a test system if you don't even believe in stage focus, which just happen to be one of the important aspects where cables can make a difference?
So far, you've been here to insist that subjectivism is a valid method of determining objective truths so it doesn't seem to me that you really have come to this thread to learn. Secondly you haven't really addressed any of the points put to you directly at all, merely repeating your opinions. Which brings me to my next point - opinions, including mine, are worthless without evidence and reason to back them up. That means in turn that concensus is a pile of crap - aiming for common agreement is a mistake, because it leaves you prey to those who will not or cannot be honest. The goal should be the truth. In the case of this thread - showing that complex audible differences between cables only exist in the minds of subjectivists.I'm here because I would like to learn why there are differences between cables while measurements may suggest there aren't any. Why can't we try and listen to each others views and try and come to a conclusion that will be in the interest of ALL.
Because? Explain to us why that is. Don't just throw out empty assertions like that.if those that do the testing take what is said here into consideration, the results may just be different.
A pity. Constructive criticism is valuable and welcome.I'm not here to criticise
You haven't helped so far - if only because you have 'helped' by doing nothing more than sharing anecdotal evidence and opinion, which are useless. As for finding answers, they've been repeatedly given to you.I would like to help and find answers
You really need to start grasping something 'blind' tests are still at risk of subjective corruption of data. You MUST use proper DBT methodology to obtain reliable results. If you realise that your testing is not good enough to prove anything, then why bother? The ONLY point of a test is to prove something, after all.I've done blind tests several times, they confirmed what I've heard during sighted testing but I also realise it will never be good enough to proof anything.
If you find it interesting that's fine, but you won't learn anything new until you start testing in the right way. If you REALLY want to repeat several decades of research into the psychology of perception and the pitfalls of subjective evaluation, that's cool. But really there's no point re-inventing the wheel like this. The work's already been done and verified - by people likely much smarter and better equipped that you. Indeed, the total man-years of work they've done is likely many many times your maximum possible lifetime anyway. Instead, why not put your energies into advancing human knowledge rather than, like Curly, retarding it? You should stand on the shoulders of giants. The view is much better up here 🙂I do my testing because I find it interesting and maybe learn something new.
Hey, Curly, why don't you start answering the questions and points put to you?Nothing has been done that has been definitive! There have been all types of studies, but nothing that clearly spells out what a human being is or is not capable of hearing. You will have to realize that there are far more people on the planet that do claim to hear differences in audio equipment than do not, but I continue to see things that suggest otherwise, except those that want to prove it us all to be wrong.
a) I asked: "Btw, any links to Floyd Toole's 'last papers'? [Edit]- can you give any info on what he's said/written/done and why you find it persuasive? Anything at all, or am I on another wild goose chase to distract me from the discussion you don't want to have ever?"
b) I asked if you were willing to take up Randi's challenge. You said you might just do so given the amount of money he's offering.
No, John.
jd
AFAIR, it is a nice and interesting reading, but i think she does provide more of a popular approach to the dark side of the brain.
But in any case it is a two sided sword. 🙂
Wishes
No, what's tragic is that the subjectivist sky has already collapsed and you just won't acknowledge it.
Still sunny and warm where I am standing. Guess maybe you need to move 😀
No to B. As to A) I found his book and read it. Quite a good read. You are familiar with Floyd Toole's work, right?
Scott I have tried a thousand times, but can not do that one. Although I do wish that I could at times like today 😀
No I was answering terry j's post about the way DBT's are done.
As if I care what you think, luckily here are people like BudP that doesn't mind using his own brain to try and understand what is happening. Those post make all this sht worthwhile. 😉
At least listen what those who "claim" to hear differences say as to where to look for them, it may just help to search in the right place.
Like making insulting remarks?
As if you have. Some of the answers made sense, most belong in highschool electronics classes.
I'm very satisfied with the blind tests I've done but you are welcome to teach me. Especially stating "'blind' tests are still at risk of subjective corruption of data".
Strange, I've learned a lot, how about a hi-fi shootout sometime, bring what you've designed and built and I will do the same. 😉
Not reinventing the wheel, just trying to perfect it, pity some still believe in wooden wheels. 😀
Just like our own Curly Woods, in fact, another charlatan who apparently conned customers out of their money for 20 years.
Now you sound like a cheap medium Doomlord.Why don't you use your medium abilities to see what Curly's customers might have to say on this?You could be wrong you know
Maybe some years after,you might be able to realize what the guy who sold you your system did to you?
Wishes
Yes it is a more popular approach. Most of the more scientific/peer studies are often quite dense, so I like to start slowly 😉
But she documents her stuff well and convincing. It does also jive fairly well with other studies about the issues I've read. There's a good book by a Danish science-journalist, IIRC his name is Tor Norretranders (with slanted dashes through the 'o's of course 😉 ) but I don't think it is translated in English.
And yes it is a two sided sword. But if you know about the pitfalls you can design your tests or whatever to minimize them. Sort of fooling the brain that's trying to fool you 😀
jd
btw, whilst I haven't read up everything on what happened between Randi and Fremer yet, I suspect if it was Randi who 'walked away' because of Fremer's requests, it was because those requests would have prevented a scientifically legitimate test. James Randi has always be strict about the test conditions - they have to be scientifically credible. Anyway, I'm still reading up on that.
NO ONE here would expect a different comment from you on this.You are already toooooooo predictable on everything.
I made enough mad that I get a call on occasion to come help them with their system setups still. Like I said before, I never sold anything that was not backed by a 100% satisfaction guarantee, period. Did they offer that where you purchased your galactic boombox there Dumb lord?
DON'T DO IT Doomlord...........its a trap😀😀😀
There's less written about it than I like. From what I can gather (and others are certainly more familiar with it than I), the test was supposed to be of Pear Cables' claims. Fremer was supposed to be Pear's samurai. When Pear backed out, Fremer wanted to continue for this to be a test of some other cables and him personally (which was not the original protocol). This either was not acceptable to the Randi Foundation or it coincided with Randi's serious illness and subsequent cutting back of his activities and the number of allowed claimants for the prize. Compared to faith healers, famous "paranormalists," perpetual motion frauds, and psychokineticists, speaker cables aren't exactly first tier...
Fremer, of course, is most famous for claiming a perfect score on a public listening demonstration but allegedly not bothering to actually keep and turn in a score sheet in advance of the key being released like the other participants. I wasn't there, but this seems to be the general sense of events.
Anyway, even with simple means you can do a meaningfull, if not totally rigourous, blind test. See here:
AVHub - Hi-Fi - News Articles - Audiophile Society of NSW - February 2009 meeting
Look at the pics, they have hidden the equipment and the cable-switching stuff. Not watertight (it's only single blind) but it shows that there really is no excuse for NOT doing it.
BTW Congrats Hugh, good show!
jd
jd
Do the results correspond with the device measurements? This isn't a snark, I'm not sure what this is meant to demonstrate. If the amplifiers were all (presumably, otherwise it's meaningless) operated well within their intended linear ranges and performed in a manner that by our present knowledge of hearing is 'blameless' (no SETs), what are the panelists hearing? This touches on the very core of the last 900+ pages, the correlation between measured performance and audibility. Either the panelists heard things that current measurements don't support, some of the amplifiers measured poorly enough for SS devices to be audible on music, or the test was flawed. Was Hugh in the audience packing heat? 🙂
It's indeed not clear. No statistical raw data (or even calculated data) were given in that link. Could be significant, could be random, no way to know. Were they level-matched? How? What means were taken to ensure that none of the amps were clipping?
It's a fun afternoon, but no more than that.
Do the results correspond with the device measurements? This isn't a snark, I'm not sure what this is meant to demonstrate. If the amplifiers were all (presumably, otherwise it's meaningless) operated well within their intended linear ranges and performed in a manner that by our present knowledge of hearing is 'blameless' (no SETs), what are the panelists hearing? This touches on the very core of the last 900+ pages, the correlation between measured performance and audibility. [snip] Has Hugh in the audience packing heat? 🙂
No idea about all this, I just posted it as an example how you could do some 'blind' tests with simple means. I don't think Hugh was in the audience, apparently someone brought an 'old' AKSA amp.
And your points are all valid, at least I would do level matching and make sure no clipping would occur.
But, as said, a simple way to do MUCH better than the anecdotal stuff.
[snip] Either the panelists heard things that current measurements don't support, some of the amplifiers measured poorly enough for SS devices to be audible on music, or the test was flawed. [snip]
Where'd you get that from?
jd
- Design & Build
- Parts
- I don't believe cables make a difference, any input?
