in the absence of any added noise and distortion
...and if it weren't for my zero balance in the bank, I'd be a millionaire.
Noise and distortion are inevitable. Interestingly, though, noise can sometimes increase resolution...
How did you discover this relation?
I have made some tests, and found that people actually prefer some distortion.
Magura 🙂
By reading about sampling theory when I suddenly had to become an expert on digital oscilloscopes to pass a job interview.😀
Re: Re: Re: Loss of Information
Perhaps the addition of 'unwanted stuff' cancel some of the wanted stuff. 😀
Whatever you prefer, the fact is information get lost throughout the whole recording and playback process.
fredex said:If the addition of 'unwanted stuff' is not the prime mechanism by which information is lost what is ?
Anything you care to elaborate?
This is quite interesting, as I have only come to the point of recognizing the effect.
Magura 🙂
For as long as there is no "reference" for the listener to consider as "absolutely neutral" or "correct",resolution and other aspects of a recording is purely a matter of perception/personal preference.
Magura 🙂
Dithering is the addition of noise to a digital system to increase resolution...
jd
jd
But how does that relate to an analog system?
Magura 🙂
Magura 🙂
The result is that the analog output of the digital system *sounds* 😉 better. Instead of correlated distortion products that sound objectionable, you get noise, often below the audibility threshold, and much less objectionable.
But I guess you know all that already 😉
jd
It doesn't.
It applies in particular to the A/D process where adding gaussian(?) noise into the signal and then averaging the digital ouput over a number of conversions provides a real increase in resolution.
Not relevant to (one-shot) audio, great for 'scopes and DVMs, if time is available.
Er isn't it only used in a bit reduction/conversion. Like 24-bit to 16-bit? At least this is the only time I use it and I really hope my A/D is not adding gaussian noise to my signal 🙂
I said it didn't apply to analog (audio).
How / why do you use an A/D to reduce 24 bit to 16 bit? That is easily does in software in the digital domain.
Some tubes, yes. I shoot for (and get) noise at -100dB or better in my tube stuff, so it's not generally a technology limitation.
SY said:Some tubes, yes. I shoot for (and get) noise at -100dB or better in my tube stuff, so it's not generally a technology limitation.
Not perhaps a technology limitation,but surely a welcome musicality view(for me at least)
fredex said:Has anyone added noise to an analog signal to see if it sounds better?
I've made some tests with identical circuits, with different noise figures, the lowest distortion figure was not preferred by all.
Magura 🙂
Speaking of adding noise, I had a strange experience the other day. Was testing a driver, full range. The day was hot so I tuned on the fan. An increase in noise floor, no big deal. A little later I moved the fan so it was between me and the driver.
Strange change in sound, to be sure. Not the "singing into the fan" effect I knew from childhood, but a decrease in bass.
After a few back and forths, it become eveident that it was an increase in the upper mids that the fan added, not a loss of bass. . Not sure what was going on there, but not what was expected - a Tonal balance change.
- Design & Build
- Parts
- I don't believe cables make a difference, any input?
