I cannot believe I have been so stupid. After all I went through getting a good deal on an amp, subs, speakers, wiring...after all the attention I paid to detail in hooking everything up...I somehow managed to ignore the markings for battery+ and ground, and got them wired backwards.
Even after fixing the wiring and replacing fuses, nothing happens. How bad did I frag this thing? It's a Cadence TXA-3004, I can get another one for ~$100, so it doesn't seem worth fixing, but jeez! How stupid can one person feel?
I haven't popped the cover since I hold out hope there's some kind of idiot-proof warranty, but there are two very subtle marks on the chrome cover near the speaker terminals, discoloration like something inside burned. From Perry's site it looks as though output transistors are a good bet?
I guess I just want to know if there's any hope before I package it up and send it back or toss it Monday. It strikes me that the fuses blew, and after I swapped the wires they no longer blow - should this be some sort of indication that they did their job and protected the internals?
Anyway, feel free to make fun of me. If anyone has any ideas, let me know. I've been chipping away at this install (subs, amp, new mids) for like 3+ weeks and now I have to wait another week to get a new amp. My patience is shot.
All manufacturers expect this to happen to their equipment. There is a diode in the amp to protect it from such an accident. As long as you had the amp properly fused, it should be OK. You need to use a meter and verify that you have power and ground getting to the amp's power and remote wires.
LOL I was gonna do that tonight and my meter needs new batteries! Assuming voltage is getting there, any idea where to look next?
thanks for the reply, your sig is appropriate here...
Get the batteries and check the power and then we can go from there. When testing the voltage, connect the black meter lead to the ground terminal of the amp.
Tragically -but in a good way 😉 you can't get a Darwin award unless you remove yourself from the gene pool , ie you are dead or unable to reproduce
So what you have done is not close to Darwin worthy - just the sort of screw up everyone makes now and then..
Mark
Mark
I know, I just feel like a complete idiot 🙂 I'll check the voltage tomorrow and let you guys know.
Variac said:Tragically -but in a good way 😉 you can't get a Darwin award unless you remove yourself from the gene pool , ie you are dead or unable to reproduce![]()
Mark
But his amp may qualify for a Darwin Award😀
I sat there and watched a friend hook up a Linear Power 5002 backwards when I was in high school, and the amp started to smoke before our very eyes when powered up. Oddly, a few months after we graduated from college, his amp was still going strong. I lost touch with him, but it goes to show that you can accidentally reverse the connections and have your amp survive!
LOL, mine didn't even smoke! It sounds like there might be hope; you guys are making me feel better.
OK, I tested the B+ and remote. The B+ is showing 11.6-11.8 volts. The remote shows nada. I am supposedly getting my remote signal from the PAC OEM-1 I'm using. So, I made a dummy remote wire and plugged it into the accessory fuse box using a fuse tap. I plugged it into one of the "not used" slots. Turned the key, heard a click, and the battery is dead.
Amp and B+ fuses are intact. What now?
OK, no edit button here...it turns out the passive anti-theft seems to be the reason it keeps not starting. This didn't happen when I installed my last amp. The only thing I can think of is there's some kind of problem with my PAC AOEM-1. I suppose when I get the anti-theft figured out I'll go and try to get the amp to power up without the LOC or speakers connected.
Sheesh, the stupidity just never ends...now my battery is completely and totally dead. It's 3.5 years old and maybe was ready to go, but now I can't even jumpstart the car. What is it about this install that could be draining the battery so instantly?
I think my plan is as follows:
1) New Battery
2) Remove PAC AOEM-1 from equation
3) Test amp with just power, ground
4) Test power, ground, remote (tapped into fuse box again, this time with inline 5a fuse)
Assuming all these work, the problem seems to lie in the PAC adapter. At that point I don't know what the best option is.
Am I on the right track?
1) New Battery
Remove the remote wire from the amp. Insulate the end of it so it does not touch the chassis of the car. Now take a short jumper and temporarily connect it between power and the remote terminal. If the amp comes on, it is fine. Then you can figure out your lack of voltage on the remote wire.
OK, so leave the B+ cable in, run a jumper wire from B+ to remote, then turn the car on? I thought allowing different leads to touch each other would fry it for sure - isn't this basically the same?
Remove the remote wire from the amp. Insulate the end of it so it does not touch anything. Take the short jumper wire and temporarily connect it between the power terminal and the remote terminal. You can stay in the trunk, there is no need to turn the key on. If the amp is OK, it will light up.
Ha! You think the suspense is killing YOU...😀
I am a totally impatient person and I tried very hard to take the time and do everything right...now I have to start from scratch.
I mean, it does sound like the battery is done, doesn't it?
I do not have enough info to properly answer that question. I would charge it and bring it to AutoZone and have them put a load tester on it.
Why don't you first try testing the amp again,to see if it is bad.Maybe I misread the afore text,but for the sake of clarity.Disconnect all power wires going to amp,for that fact remove amp from car. Take your meter,you know the one with fresh batteries,put it on the setting that has the either the greek omeaga symbol or the triangle with a line.Place the leads into the Pos. and Neg. inputs of the amp.Doesn't matter which leads go where.And reply back with what you get.
Hope I haven't sent you around in circles.
- General Interest
- Car Audio
- I deserve a Darwin Award
