i bought this to make hi-fi knobs :)
Hi Dangus,
You could use an optocoupler and a contactor to do this. I wouldn't wire the primary current through your micro switch directly. I've replaced more micro switches in my lifetime and this can be avoided.
You could just wire it up to a warning light as well. Use an LED type.
-Chris
You guys just don't have any imagination. What 'ya do is wire the opto not only with the power switch, but to a big contactor across the mains. If you forget to replace the key in it's "home", the contactor crowbars the mains and blows the breaker when you throw the switch. Then you have to go to the basement with a flashlight and reset it. Now what you have is a true behavior reinforcement system. :devilr:
Seriously, the opto key home is a great idea, and actually serves two purposes. Not only does it insure the key is in a safe place, but it's where it should be every time. It seems like I never set anything down in the same place twice, so I spend more time looking for chuck keys, than I do using them. :clown:
djQUAN said:
I don't worry about leaving the chuck key in my drill press chuck since I got my drill press second hand with the key missing. :clown:
I just got ROHM keyless chucks for the tailsotck of the lathe and drillpress, German made as well. they are very accurate and nice to use! (and no key to lose!)
The milling attachment is coming along nice, i will post some pics when it is done.
I wanted to take the chuck to look for replacement keys but I have no idea how to remove it. I originally thought there is a screw deep inside the open end where the teeth was but there isn't so I left it as is. I hand tighten it and it works so no rush. :smash:
It's probably a morse taper - there's a lot of info if you search.
Sometimes you'll never get it off though😡
grab the handle on the drill press, lower the chuck, place block of wood between edge of chuck and the upper body.
quick jerk up on the handle should knock the chuck off.
Always clean a morse taper before putting it together.
Even easier, buy two of those 4-way universal keys because your'e going to lose one again.
Emergency chuck key:find the perfect size drill bit, put it blunt end first in one of the chuck key holes.
Use a large flat screwdriver that fits neatly into the teeth on the chuck. Lever against the drill bit. be gentle because you can apply massive force with such a lever. I went 5 years on a drill press doing this, never did get around to buying a key.
that could work. 🙂
thanks for the ideas guys!
:smash: :smash: :smash:
If you invest in VFD with new three phase motor, you could easily change the speed without loosing the power. On the top of that VFD has additional circuits and relays that allows you to install different switches that could shot the rotation. After that is just your imagination how you utilize that.
I modified my mill and lathe with VFD and I am very happy with it.:smash: :smash: :smash:
Here are some more.
design is by Geek, and thats who they are for.
