I am hoping some of you may be able to help. I am new to Gainclones and electronics.
Does any one know if I can buy the Chipamp.com or Audiosector.com PCBs in the UK? It would be easier to follow one of these kits.
I am really keen to make my own PCBs if someone has a simple yet reliable PCB design I could use.
I have purchased some copper boards and intend using the photo glossy paper method.
Which size toroidal transformer will give me the greatest flexibility with future upgrades? I have seen some at http://www.airlinktransformers.com/...ransformers.asp
Which amp configuration will best suit my these speakers?
B&W DM601 S2
Crossover is at 4 kHz, efficiency is rated at 88dB/1W/1m, Impedance is said to be 8 Ohms nominal, 4.3 Ohms minimum
Response 70Hz-20kHz +/- 3dB on axis
Harmonic distortion below 1% 88-20.000 Hz at 90dB SPL at 1m.
Power handling is said to be 25-100W continuous of unclipped programme into 8 Ohms nominal
I really appreciate your help.
B&W DM601 S2
