I am not able to add pics under android.
Thanks in advance for reading this thread.
I have a win xp notebook and an android phone. All OK with the PC but in this device I can't upload images nor any kind of files. Untlil the pop up where one select the file(s) to upload, all goes OK, but the upload file buttons appears inoperative or insentive. Is a problem mine?
I have a "Samsung Galaxy A01 Core" device with Android 10 Spanish version installed from factory and with all updates installed. No add blocker.
Salu2 para to2.
I think the OP means he is unable to upload images from Android.
Now I tried it, with the following sequence:
Post Reply
Manage Attachments
Select file (this is in localized language, in your case it should be in Spanish)
Select operation (also in Spanish)
Own files - Internal storage or SD-card, here you can select a single file from DCIM - Camera, then you are back on the Select file page
Now swipe to the right, because the Upload button is off screen
After uploading, Close this window at the bottom of the page
That's it.
Test
Post above from my cellphone.
I don't know what that image is. I don't seem to have any small images on my cellphone. I need to study the folder structure more. As lcsaszar says, Android has multiple places it saves things.
And my cellphone is FAR too small to navigate DIYaudio or its upload dialog comfortably.
This was Android 8.1.0 on an LG LML413DL.
