It has 2 holes 18 cm 1 woofer and other midrange and 1 hole 10 cm tweeter it was given by someone for free
OP has a single Woofer with dual (4+4) voice coil.
Not 2 Woofers.
Note:
Midrange 8 ohm ( Mark audio maop 11)
is a full range speaker.
Most beginners start with a speaker kit with drivers, crossover components and a box plan so they can build a proven design; not a random collection of speakers and a box.
Not 2 Woofers.
Note:
That sounds like a waste of useful space .
I have already bought the speakers .
And even if there are a lot of mistakes it is no problem I will fix them one by one and I will also learn in the process ( I am having fun 😁)
Not 2 Woofers.
Ok, great. I missed that part.
I do not foresee any issues with fullrange, he is going to use steep crossovers.Note:
Yes, have fun. It can work in the end. Do not forget that L-pad for tweeter, and mid needs its own inner enclosure.That sounds like a waste of useful space .
You’re going to use it for PA? Could you specify what PA? Are we talking music for parties, church sound reinforcement or what?
Not at all. Just make sure you connect two coils in series with propper polarity...otherwise coils will cancel out.Does the 4+4 subwoofer change the crossover diagram?
How do I calculate the L-pad for the tweeter mine says 300w rms and 600 w peak but there is no way that the tweeter uses more power than the subwoofer which uses 200w rms and 400 w peak
My tweeter uses 0.05W, a dome will use a little more than that. It's customary to use 5W resistors but you can learn more if you ask a simulator to do some calculations for you.
I would use variable Lpad, that way you can dial in any value. This is just an example.I see do you have any recommendations?
https://www.parts-express.com/speaker-components/crossover-components/speaker-l-pads
https://www.parts-express.com/L-Pad-15W-Mono-3-8-Shaft-8-Ohm-260-248
Lpad goes after crossover before tweeter.
- I am a beginner and i need help with my speaker build
