I built a comparator using TL074, actually 1/4 of that.
everything works!
when I send audiosignal into comparator, LED will flach according to the signal.
but it flashes too fast. I want it to flash not so much-I want it to work for 30seconds after it has light once.
signal comes for 1/2 seconds, led works for 30secs.
can i do it adding a hysteresis to comparator or I have to add some transistor ana capacitor as well?
Thanx..
W@ldur
everything works!
Thanx..
W@ldur
no need for a peak detektor, I only want short flash into a longer "burning".
time relay or smtg.
time relay or smtg.
hysteresis reduces a comparator's susceptibility to noise, eliminating false triggering.
what you really want to do is add a time constant to one of the inputs of the comparator -- V = E^-(t/RC) -- then you have to figure a way of discharging the capacitor as the input impedance is not low enough to drain it.
take a look at Rod Elliot's VU meter project and you'll get the general idea.
