I switched from class A (DIY Death of Zen by ESP; overall a very nice low power transistor amp), to AB (DIY Gainclone LM3875; better bass, better dynamics) to class D (Sonic T-amp; great sparkle, voices/cymbals crystal clear) and finally the (DIY) AMP6 from 41Hz (same signature as Sonic T but even more of the goodies and lots of bass). This is my main amp now. And finally...yesterday I started with the prototype 10W class D monoblocks proposed one year ago by Brian W (BWRX). (Sorry Brian, I told you; terribly busy and so on. They will be great though!)
Shortly I will listen again to all amps (blinded! together with a buddy of mine to do some comparisons) but I have this feeling that class D is still surging ahead in sound quality while the more conservative topologies are more or less stationary. Doesn't keep me from trying out new amps all the time though (after the BWRX modules, I'll probably going to do the Pass F4).
All this btw. on Fostex 108EZ drivers in Buschhorns MkII without filters or damping.
I've listened to the TACT millenarian II and found it very clean with good soundstage image width and depth This is what I would consider as a class D reference. Having listened also to many linear amps such as Goldmund and MBL amps, I would say this amps are not as neutral as the TACTs, but have their own pleasing sonic signatures that make them easy to fall in love with. The NCD I have has some sonic features that are also quite nice, not as clean and precise as the TACT.BWRX said:
Some class d amps already out on the market have been given very favorable reviews compared to "state of the art" linear amps.
Ouroboros said:I would say that Hypex still lead the field, but I do have concerns about the short-circuit protection of their amps.
Any special reason ? I have not been able to blow up my UCD180's yet, and I have been trying quite hard (evaluation for possible commercial use). From my experiments with the Philips circuit, it soon became apparent that you need both overvolt and overcurrent protection, but I've found the UCDs seem to shut down OK with a short applied- even under heavy load conditions.
I'm designing both a 60W and a 150w Class-D amplifier for the company I work for, which will be part of a 'voice-alarm' / PA application. This amp will feed a 100v line speaker system via a step-up transformer and so I need post-filter (but pre-transformer!) feedback to keep the required frequency response over a wide range of load impedances. I've had a bit of trouble in getting a short-circuit protection system that fully protects the output FETs when a short circuit is applied to the outputs when the amp is playing at high output volume. I initially tried using one of my UCD400 units as a reference test unit (feeding the 100v step-up transformer) and it killed the ouput FETs as soon as I short-circuited the output.
I don't know if the UCD amps implement proper cycle-by-cycle current limiting. Certainly the original Philips reference design shows a current limit circuit that is hopelessly inadequate.
May I know what is the difference between ICE module from B&O and Sanyo chip? Is B&O module using the Sanyo chip?
Thanks.
Thanks.
In the UK, the Sanyo modules are sold by 'Sequoia'. a UK component distribution company. they have the data sheets on their website.
See: http://www.sequoia.co.uk/silicon/manufacturers/Sanyo/class_d.php
Thank for the link, but the download only show 3 pages of blank sheet. :-(
Do you build the PCB for the Sanyo chip?
Yes, I bread-boarded the sample I have of the DIL module onto a pcb. The amplifier works very well indeed into loudspeaker loads, but it had problems when driving the step-up output transformer to drive the 100V loudspeaker line.
I've just checked the Sequoia website, and the links to the data sheets do seem to be broken. I have the Sanyo data, but perhaps it might be available directly from the Sanyo website. I don't know what the nature of the business agreement is between B&O and Sanyo.
Class D - Sanyo
I found very interesting the product / hybrids from Sanyo.
I am looking to the STK428-640, used in some JVC equipments, but I cannot find the datasheets or the tech notes, does someone knows I to find it?
The Sanyo web site has only some brief infos and the distributor Sequoia shows just a preliminary presentation.
Thank you!
Thank you!
I've got all the data from when I was looking into these (November last year). It's in a 7 Meg Zip file. Do you want me to email it to you? Drop me an email with your direct email address and I'll send it to you.
I've not seen else much about these chips and modules from Sanyo. Perhaps there's some business or technical issues holding things up?
By the way, if you hold down the control key while clicking on the PDF file download on the Sequoia site, you should open a window to allow you to register to download the files.
I agree - if you build the Philips OCP as drawn, it wouldn't actually work at all !(D1 and D2 are shown reversed on the fig 9 schematic).
It also needs to be used in conjunction with OVP, otherwise the negative rail pumping justs destroys the output devices, with a short applied.
I think the Hypex amps (well the 180 anyway) uses just a current sensed OCP - I can see no reason for the 0.5 R Dale resistors otherwise. My versions also include Lm393 comparators, and a 4093 Schmitt NAND, which I suspect is used to trigger the amp 'off' function, when either over volts or over current are detected.
I have not been able to destroy my UCD 180s, even when applying a short across the secondary of a 100V line transformer load, under full signal conditions- although that is only with +/- 28V rails used.
I did manage to destroy the output devices in my own version (based on the Philips circuit, but with differential feedback, and both OCP and OVP fitted), but only if I used the recommended Philips devices. If I use IRF520 output devices, with their higher Rds on resistance, it seemed OK.
It seems strange that Bruno would have allowed such an 'iffy' protection system to be fitted to the UCD 400, when he has clearly taken such care with the rest of the design?
Although, as I say, I have had no problems with the 180 (so far!!)
actually they are 5mOhm, i.e. 100 times less than .5Ohm 🙂
-CGL- said:To op. - check out Elektor September 2007
Thanks, I will.
Any ideas how I edit the typo "BuForce" from my post?
Still looking for comparisons. Are any of the Hypex / NuForce / Coldamp / NewclassD amps BETTER (Sonically) than a Bel Canto Ref 1000?
Thanks again!
Ian
Of course, my mistake, sorry!
That really must confirm that they are the overcurrent sensing resistors then?
Heres the Japanese datasheet for the STK428-640 can't find an English version, the english page at sanyo.jp has no link.
James
James
Yes, OCP is: 5mOhm->discrete voltage amp->lm393
- Class D
- Hypex or NewclassD? Which is the Best Class D Amp there is????
