I could lower volume in foobar2000 music player, but it decrease sound quality.
Why would lowering volume decrease sound quality?
bbest, with a 24 bit volume control and correct dither you need not worry about reduced quality until you are beyond -20db attenuation.
As in way beyond. Starting at 24 bit, and applying no dither, you still have 16 bits (96 dB) of dynamic range left even at -48 dB attenuation. Add dither, and you have much more.
Keeping these blighters cool is a problem. Not as good as other class D amps. The iron ware could be better quality in the choke.
Crikey - glad I mounted mine in finned cases.
Thanks for answers guys!
May be active preamplification will be best choise. Something like this Vorführverstärker - Seite 2 - DIY-HIFI-Forum. But I don't know where to buy this preamplify
bbest,
A stereo build with a passive attenuator in front of the amp modules should work too.
The question whether one prefers to mess around in the digital or in the analog domain. Personally I still believe more in high quality active preamplification
Depends - do you need active amplification and the functionality a preamp provides?
A few users have reported heat issues, but most people have reported their ncores running cool. Have you checked that your ones don't oscillate?
All of a sudden one of my nCore modules is producing pink noise, even when volume is idle or muted. I tried the other 4 modules, trial and error, but no problem. Just this one. Any ideas?
Just to state the obvious - sounds like a faulty module. Have you contacted hypex?
I'd say that "best" would depend on what someone like/prefer
Best to my or your liking is not necessarily best to someone else...
Absolutely - but if someone asks for advice, I'd like to understand what the requirements are.
Hello,
what do you base this comment on?
Hello,
Hi Julf, I brought it to Hypex this afternoon, together with SMPS. Now wait...
Please let us know how it goes!
They were pretty good when I had to RMA one if my modules. You have to think with such bleeding edge technology there will be a small % of issues.
I hope you get your issue resolved quickly.
Agree -if there is no need for selecting input and if one prefers to adjust volume in the digital domain, then active pre would not be the way to go...
And not having the active pre might even lead to better sound quality. All depends on the situation.
- Class D
- Hypex Ncore
