Yes, if you are using the power supply to switch the amp on and off.
What about a switch in between the live on the power? Still need the black wire?
If you use the power supply to switch on and off the amp (SMPS Standby on the SMPS600), then all you need to do is to connect the black wire to ground.
jtwrace, are you going to be grounding your chassis to earth?
I'd like to.
Red Pin 2
Clear Pin 3
Yellow which is really the shield Pin 1
Switch inline from the IEC to power on/off. Does the black wire still need to go to chassis?
Also, the print shows that Pin 1 goes to chassis too.
i've been looking at the datasheet and am slightly confused about how to go about wiring if the supply has a third ground conductor and it is connected to the chassis. Does the wiring shown in the "preferred method" for balanced connections still apply the same way with the microphone cable shielding conductor hooked up to the chassis which is also currently bonded to earth?
Forgive my ignorance here, but what are the other options? You have a power switch that turns everything on and off, via the the power supply. Or you have a power switch for the power supply, which you presumably leave on and a separate power switch for the amp, which you power on with use. Apart from power consumption, any reason to do one vs the other.
Thanks.
Alternative 1 - switch on mains power to power supply.
Alternative 2 - use SMPS Standby control input on power supply to switch power supply on and off
Alternative 3 - use nAMPON input on amp to turn amp on and off
I think the recommended way is alternative 2.
I assume that by "supply" you mean source, not power supply?
Isn't that then exactly the case described in the "Figure 2: preferred connection" picture?
sorry, meant power supply as in higher voltage 125/250 VAC.
Ah, sorry, misunderstood you. Yes, you still connect it exactly the same way even if you use a 3-pin power cable. No problem with balanced interconnects. With unbalanced RCA's you would have a much trickier situation...
ok wasn't to sure, in my mind it didn't seem right to connect my 125VAC earth ground to the chassis and then the shielding conductor to the same place.
Hi All,
as many, I am waiting for 2 x nc400 + 2 x smps600 (3rd batch).
What about these rca/xlr converters (Lundahl transformer inside)?
CANFORD BALANCED TO UNBALANCED CONVERTER PHMXMH Inline, line level. XLRM to RCA(phono) male
My preamp is a LDR passive Eva.
This is best practice in most cases, see AES48. That way a low-impedance web of shields surrounds everything except the amp outputs. Earth ground is earth ground, I like to say it's "accessed via mains ground" since it should have almost zero voltage, just sayin' 🙂 .
So you can still connect via the preferred method and have mains ground to the chassis. Correct?
Yes. As longh as we are clear that the preferred method is fully balanced, using XLR's (or other fully balanced connectors/cables) and a balanced source.
Is there a way to check if the source is fully balanced and not just using xlr connectors in a non balaced configuration?
If my source (dac) uses a 3 wire power supply (120V), and the ground/earth wire attaches to the chassis, can I use a multimeter to check for continuity between the chassis and pin2 of the xlr to see if they are both bonded to earth/ground? Would this tell me if the dac is actually fully balanced?
You will still be OK, even in the unlikely scenario that the output XLR of your DAC is not balanced. It just turns into the situation in figure 3: "How to benefit from a balanced input even if the source is unbalanced" in the nc400 data sheet.
You would probably not damage anything with a multimeter, but I would still recommend against trying to measure the DAC output.
The Ncore would be fully balanced buy my pre or source are not. SO I'll be using the preferred hookup with benfits from using a balanced amp without a balanced source. 🙂
- Class D
- Hypex Ncore
