Hypex Ncore
Yes, but 1200W is a must for better dynamic headroom in the bass region. That said, both UcD400 and DS4.0 sub-amp is enough for most subwoofers out there. I managed to almost destroy a SEAS L26ROY driver in a 40 litre cabinet with passive radiator using a Hypex DS4.0. 400W is plenty - to some degree 🙂)
Vidar
dimensions ?
Hi Bruno,
what are the dimensions of the nc400 and the smps ?
no need to be accurate. I understand if you'd rather wait till the final released versions.
I only ask as I'd like to source an enclosure, but don't want to get something too small.
Fantastic work, thanks so very much for making a DIY version !
I look forward to building a pair of these amps. i assume the smps is for a mono-block.
please take your time to get everything right, I'm happy to wait for any extra month or two. Will give me more time to same some money. (we'll see if i need to use euro's or dollars or francs or .....)
Gareth.
(i'm not sure if i should get a new pre-amp too, the one i have is not balanced. I have seen the musical fidelity a1-bpa being sold off in the uk. )
