Hypex Ncore
If there is also a star ground.
Doesn't really matter in this case.
In this case you have 2 connection points between the PSs.
Yes and no. You have two connection points, but one only goes to the relay coil/optoisolator of the control input, so it is galvanically isolated from the rest of the SMPS1200 circuitry.
Personally, I prefer to have the grounds of the channels isolated from each other.
Sure, we are all free to follow our personal preferences, but in this case there is no rational reason to need the grounds isolated from each other.
I want to connect the grounds where I want: at the input, at star-ground or nowhere.
Could you not use a pair of diodes, each in series of the ground of your trigger circuit to the grounds of the SMPSs, with the anode pointing to the SMPS? It won't be galvanically separated, but there should be no risk for any ground loop. The voltage drop over a diode is only 0.7V IIRC, so no problem reaching the 3.3V min spec.
The LTV827 has a forward voltage of 1.4 V, so for a nominal 20 mA current, the 220 ohm series resistor makes sense for 5 V - for 12 V I would add an extra 300 ohm resistor.
From the SMPS1200 datasheet, regarding SMPS standby:
"Note 1: The current (A) drawn can be calculated as follows: (Vpin – 1.2) / 220"
This formula makes sense for an opto coupler with 1.2V forward voltage connected in series with a 220 Ohm resistor. (It doesn't make sense if it was a connection straight to a relay.)
Hi guys. I hope to get a little input to a hard choice reading this whole tread hasn't clarified it 🙂
I'm going for NC400 or NC500 (with standard buffer). These two systems will cost almost the same but of course I would have to assembe the NC400's my self.
My system is MDAC and Dali Euphonia MS5 speakers (4Ohms, 89dB sensitivity).
The advantage with the NC400 is that I can reduce the gain and thereby avoid a U-pad attenutor and slightly better low load performance.
The advantage with the NC500 is higher power at nominal load, higher headroom with bigger PSU and lower distortion at power levels less than 20 watts.
513736d1447184905-test-data-graphs-consolidated-12-popular-power-amps-class-d-ab-h-aaa-thdvswatt8ohm_all.png
Has anybody heard them side by side? Is the NC500 an improvement in audio quality? I've read some people claiming that but other thinks there is no difference. I guess there should be a little difference since the input buffer designs are different.
The choise is between NC-400 without U-pad attenuator or NC500 with attenuator (but better specs?) What would you guys choose? 🙂
