Had similar problems/ Without warranty here the procedure written up by Ian based on my experience:
... instructions for DC and calibration reset
http://www.diyaudio.com/forums/vendors-bazaar/190434-hypex-ncore-407.html#post3029221
Thanks for these instructions, but before I will calibrate, I tried the last step several times (using two alkaline 1,5 v batteries; according to my volt meter 3,2 volts in series).
Is this enough? I tried this several times as described.
After this step however, with nothing connected, the problem remains, the smps just seems to keep clickicking (protection I guess?).
I added a link to a sample I made of the clicking sound, I am not sure if this happens I can calibrate at all?
No lights are lit on the amp, I guess before that the amp might be switched of already?
You did notice the "No DC power connected (No SMPS)"?
Does the SMPS itself start up and stay on OK (without the nc400)?
Yes, SMPS was disconnected (nothing connected actually), so just the NC 400 module I applied the 3 V to pin 1 and 2.
When I disconnect the NC 400 form the SMPS600 and witch the SMPS on it clicks after 2 seconds once, and I expect that it is on. So no repetitive clicking sound every 2 sec, so I expect it to be ok?
Might still be worth verifying it with a multimeter.
I will, just to be sure.
But I suspect/hope that the SMPS is fine, and the NC400 is locked in some error state. I hope I will be able to clear it somehow, maybe my battery powered reset is on pin 1/2 is not good enough? Is it to clear some flash memory/flush error state?
A milliohm output impedance should be more than adequate for the job 😉
Seems like you have never listened to a low Q system.
Could you explain how your "low Q system" is specified (value of system Q; -3dB LF bandwidth)?
At DC possibly. But how much at 50 Hz you think?
Wouldn´t that depend on the reactance of the coil, hence its inductance as you probably know...
If you imply to simply collate what make up the total impedance in terms of assessing the theoretical damping factor of the system (in relation to frequencies), then my guess is that something important is left out.
Have you tried various coils and resistors and heard their effects on a (bass) system? 🙂
cheers,
My humble guess is that the low out put impedance was implied to maintain a low Q for the system.
It could sound like that you have gone to great lengths to get a low Q on the speaker side of things -only to depend on having some output resistance on the amplifier end. Nothing wrong with that, but a 0,03R coil sounds like an expensive solution if you really don´t want a total system Q that is as low as it provides.
What kind of woofers and enclosure do you have and whats the rest of the filter on the bass section, if I may ask?
As I understand it, it forces the onboard supervisor to recalibrate itself.
Sorry I do not have that anymore. Here is ts for my midrange. Maybe you can imagine how my bass works then.
No I can't; midrange is a bit different from bass 🙁
I got those coils because of my amplifiers at that time. Earlier it was a DCA cast with 0,5 ohm . That was no good match for my non feedback The End XP . Now I have those coils and with my new amp it is just perfect. What difference do the rest of my filter make in this combination ? It is a 18 db acoustic filter and 12 db eletric. The enclosure is aprox 140 l.
This is to much about my speakers in this tread . Nothing more about them.
Yes but not much in this case !
Agree; it does not make any sense to discuss the loudspeaker - amplifier interface when you don't know the actual performance 🙄
cheers,
My point exactly. A 3.3 mH coil will have 1 ohm impedance at 50 Hz. Thus the driver will "see" a 1 ohm shunt impedance at 50 Hz.
I haven't crossed over sub's/woofers with a passive network since the 80's, so I really can't comment on your last question.
How low a Q is it and why would the ncore not be suitable to drive it ?
He said he doesn't know, so I don't get the point either 😱
Q is around 0, 28 . Low Q is very tight bass.
Combination with the very tight bass from N Core results in almost no bass .
- Class D
- Hypex Ncore
