• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
Hypex NCore NC500 build
Also, I'm not sure we really reached a satisfactory conclusion regarding DC coupling. I understood that while the introduction of a DC blocking cap in a line input adds noise - just make it large to reduce the noise contribution - DC coupling of amps was still "unwise" practice. Is this now considered unnecessary?
I think people who run a completely DC-coupled chain are very brave - and have hopefully have verified their DAC or other source doesn't have any DC offset on the output.
As an owner of the Nord nc500 rev c amps with the 994 input buffers I can say these amps are the real deal. Rest of the chain is an Aurender N10, T&A DAC8 DSD, Hattor passive preamp, Von Schweikert VR5 Anni MKII. I also have a ARC REF75 with KT150 tubes and the Nords do many things better than the REF75. I could easily live with both but this is a testament to the excellent quality of the Nords. Mike was the one who told me about Colin with Nord after I had the Hypex nc400. I truly think Mike has a good set of ears attached to his head but his methodology to relaying his ideas is on the brash side.
I don't think any of the "bickering" (could we please try to avoid the unnecessary derogatives?) has had anything to do with class D per se. I think we all agree the hypex amps sound good - and for those who perceive transparency as "cold and sterile", there are lots of ways to add the coloration they prefer.
You answered for me. I would have answered : "now it's working as it is colored 😀" .
I agree of course with JULF. If I have a DAC sounding the way I like (near the mixing of the reccording or not btw) I want an amp which doesn't change this... All these discussions were about to change the sound of the HYPEX by adding distorsion (buffer pcbs, caps, etc!) .
You may like it, but we can't says it's better, we just can say it's nicer to ears and if colored you will find someone able to find this is not so accurate... We can spend money for this coloration as it is about aesthetic if not liking the straight sound of Hypex... but if these buffers became as expensive than the OEM module, you are not anymore in a good product but a marketing trap ! If I picture with cars : in A ferrari the earth is the motor, not the autoradio ! this last should not cost as expensive as the motor to make noise !
What makes you think that the opamp preferred by most, the SIL-994 is colored? It was designed for pure transparency, not coloration. Sonic imagery Labs isn't an audiophile fairy dust company. Most of their clients are in the pro world.
that is a mighty good sound.. which amp, if you please kindly tell us, do you use more the AR or the Nord?
It is maybe not this component but all you add around and interactions with pcb and circuit above. You add passive and active stuffs, it can not be neutral. But I don't say the result is bad at ears... I just think we enter in the world of subjectivism as we saw in the thread by the tries of many buffers. I know people who add btw tubes in input with excellent results as well at ears....
What I like in the idea of the NC400 is : it was designed as a whole.
The NC500 with the 994 buffers sound better than my Hypex NC400.
You mean the connections and the supporting caps and resistors? How do you suppose an I/O buffer board should be built? You think this THD+ N plot is poor?
Is there something on the SIL-994 datasheet that looks like a red flag for distortions and coloration?
You know the flagship Hypex amp the Mola Mola Kaluga uses an external buffer board as well. Same with all of the best Ncore based amps. All of the OEM Hypex amps have an option for external buffer.
