Hi Everyone,
Hoping to poll the wisdom of the group here, as I'm a mechanical engineer who can't help but tinker with electronics. I have recently come into possession of a Hypex NC502MP amplifier board, and I have a question about power standby switches and 12V trigger inputs from AV receivers.
I have read the datasheet on the hypex amp a few times, and it seems I can use the low power SMPS with a 12V trigger to turn the main SMPS and amplifer section ON when I feed a 12V DC signal to the proper pin. At the same time, I would like to include a standby power button on the front my amplifier case in the event I need to unplug the speakers, and I can't reach the rear of the amplifier chassis. That said... I can't quite think my way through a switching or relay setup that would allow the 12V trigger to work, and the front power switch to interrupt it.
Ideally when I press the front power switch, the main SMPS power would turn off, yet this state would not be remembered by the amp. In my head this equates to a reset condition, where turning off my AV receiver (removing the 12V DC trigger voltage) would reset the standby switch. This way I won't have to walk over to the amplifier and hit the front switch every time I forget, and wonder why the 12V DC trigger didn't work.
I hope I've made some sense here, and that someone's got a relatively simple solution to show me. Remember... I'm a mechanical guy, so assume I barely know the difference between a light switch and a...well crap, I can't even form a good metaphor there!
Thanks in advance for any help!
The PS Enable pin must be "high" for power on. 3.3 to 12v.
This can be sourced from the Standby-SMPS.
A simple latching on-off switch can do this.
If you want to switch from an external source (eg a pre-amp which outputs a trigger then the safest way is to use a transistor in place of the above switch, your external source switches the transistor, thus you are not exposing the amplifier directly to external signals.
Anaview AMS0100-2300 build
A suitable circuit for external trigger, high to enable, low to disable.
Hi Madtecchy and RussC, Thanks for the replies. My goals here are to use the Hypex amp with a standard AV receiver. If I can properly include a 12VDC trigger function on the Hypex amp, then I can get the Hypex to power up when I turn on the AV receiver. I'm just trying to avoid the requirement of physically touching the Hypex unit to turn it on and off, unless I am plugging in speakers.
So, as you guys have mentioned, I would like a latching switch on the front of my chassis that will control the PS enable signal that is sourced from the standby SMPS. Ideally, I would leave this switch latched in the ON position, so that the AV recevier controls the Hypex amp by sending the 12VDC trigger signal.
I have some Crown XLS1502 amplifiers that can use this kind of "sleep mode" using a 12V contact closure, but that requires a relay rather than a simple 12VDC signal. I'm just trying to bake a similar function into the Hypex.
Does that still require a transistor to accomplish?
Thanks!
Thanks!
