Hypex in Counterpoint chassis
I have a pair of Counterpoint SA12s that are both working perfectly well but I understand the output devices are no longer available and if anything goes wrong with them I would have to look elsewhere.
So my question is - could I retrofit hypex modules and if so which ones. A peek inside at the circuit boards which says that the rails are +/- 40v (I haven't measured this, but assume it is right for the time being). From the hypex site this suggests ucd 180 modules. Assuming the ucd 180 will work with this rail voltage can I assume that I could connect the hypex into the power supply of the counterpoint, mate up the hypex heat sinks to the existing heat sinks of the counterpoint and connect the input and output connectors and have a nice new (nice sounding, cooler running and hopefully long-lived) amp using my existing case, transformer etc.
The one issue I can think of is do I need to organise any sort of soft start on the Counterpoint's power supply. The amp currently takes quite a while to start which I assume is a timer module or the warming up of the valve stages. From what I can see the power connects straight into the transformer and that there is no soft start or similar on this side of the amp. If anyone is familiar with the sa12 or has done a similar conversion I would be very pleased to hear from you.
regards,
Nigel.
Minion,
The SA-12 and SA-100 have both N-channel and P-channel MOSFETS, not just the N-channel ones. As I remember, they used fairly rare ones which ARE not manufactured anymore and hard to get. But...
Tvrgeek, can you provide more details on what you did to install the Exicons. Many of us with dead SA-12's and SA-100's would love to have that information!!!!
Greg in Mississippi
