I recently bought a 2nd hand Hypex HS200 with a Shiva III to build a subwoofer (http://matthew.augier.info/index.php?album=/DIY/STS_II) from a guy who I trust to be honest. Got to the stage today where I wanted to test, connected it all-together and nothing. Everything is connected as it should be (green euroblock + to shiva+>+ and same with - side. But not a bean out of it. When the panel powers on in standby mode the light is yellow, and when sub sounds cut in it goes green as expected. So I tried another driver (8-ohm direct connect bsb-12) still nothing, which makes me think something is wrong.
My connection is only mono and the panel has stereo in, I tried left/right which made no difference, does it need a y-adapter?
Something else wrong? Any advice welcome, I want to get this baby rocking (yes it's a svs clone, and I'm just waiting for the to grill)
I've tried another driver ont eh panel, so same thing. It does look possibly like a dry joint now, it's being investigated further.
For this plate amp I am looking both for an instruction manual and a service manual/schematic diagram.
Thank you very much for upload.
This URL's don't provide the wanted files:
https://www.diyaudio.com/community/threads/help-with-hypex-hs200-and-new-sub.24354/
https://www.diyaudio.com/community/threads/which-subwoofer-plate-amp-to-use.10032/
https://www.hypex.nl/producten/archief
This URL's provide only short form data and images:
https://forums.audioholics.com/forums/attachments/hs200-pdf.23982/
https://www.springair.de/en/hypex-hs200-active-bass-module-with-crossover/47281
https://www.dsecomputers.de/documents/produkte/home/aktiv.php
