hybrid speaker
Hi everyone .
since i'm an audiophile crazy it's been a while that keeps buzzing in my head one thing (i don't know why). 😀
a speaker that uses many permanent magnets each with its own voice coil (same principle as the cone loudspeakers), all together moving a single large membrane (as in planars).
practically a hybrid that combines the characteristics of two different worlds, magnetoplanar and cone magnetodynamic loudspeakers.
exist ? to you it appears that some builder or some do-it-yourself has tried to build one? .
how do you think it would be?
not to forget the Technics AFP series, models 10, 100 and 1000.
Seemingly such drivers became too expensive to build as the ´motors´ required close matching to not generate additional bending modes on the membrane.
What hasn´t been done so far commercially -afaik- is to use multiple coaxially mounted voicecoils* to create an true digital speaker.
jauu
Calvin
*meaning each voicecoil been driven by a bit-weighted pulse signal current, a direct digital drive - DDD
Besides the reduction of conversion stages in the signal chain -just a power-DAC needed- the coil´s inductance would form the required output filter for the Power DAC.
Seems self-evident that progress in audio has been tied to feedback. In this case, usually motional feedback related to cone motion.
Not a good use of design effort perfecting drivers when factors beyond the control of the enineer's blueprint can modify (that is, screw up) the output. Whatever the source of distortion - manufacturing tolerance, driver distortion, box, room... - corrective feedback aims to fix it.
Always good to hear from Calvin.
B.
